Air Conditioner High/Low pressures and ambient temperatures
Discussion in 'Volvo Forum' started by SuiteSuccess, Aug 18, 2024.
  1. SuiteSuccess
    SuiteSuccess Bobtail Member
    9
    4
    May 31, 2023
    2006 Volvo 780 D12. My air conditioner is not cooling as well as previously (probably small leak). I've not had a problem prior to this. I have access to hose gauge set for recharging if necessary. I use R-134a. My question is in looking at the high/low side pressures and ambient temperature is the chart specific for my truck or can a standard generic R-134a chart be used like this one to gauge whether I need to add coolant?
    Refrigerant Pressure Charts | A/C Pro®
  3. Animosus
    Animosus Heavy Load Member
    743
    3,007
    Dec 7, 2015
    SE Wyoming
    The generic chart works on any R-134A system. Make sure your condenser is clean and clear of any debris, it is often overlooked when dealing with A/C problems.
    beastr123 Thanks this.
  4. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    Also make sure expansion valves are clean pressure chart works ok somewhat but when u are considering being low on Freon it a hard to gauge better remove and scale and charge properly
    Snailexpress Thanks this.
