Air Conditioner Problem 3 shops can't find problem so far
Discussion in 'International Forum' started by Edgrmndz, Aug 9, 2018.
  1. Edgrmndz
    Edgrmndz Bobtail Member
    41
    37
    Feb 15, 2016
    2012 International Prostar with Maxxforce 13.
    The A/C won't turn on. the compressor doesn't get juice. I already took it to 3 different shops and
    they all give up on it, can't find the problem since its electrical.
    The compressor clutch engages when tested , the freon level is good. i had to manually put electricity to the
    line going to the compressor to make it work. the last mechanic put the computer to see what was going on and after changing a couple of parts located by the blower, his computer shows that everything is ok but still the a/c won't work ..i have the video on you tube if you care to watch it.
  3. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    @Heavyd will be along shortly to guide you down the best path....listen to what he tells you, the man knows his stuff!
  4. trulytex
    trulytex Light Load Member
    63
    24
    Feb 6, 2013
    Okeechobee, FL
    I have the same problem with one of my 2012 Prostars. It will blow cold for 2 - 3 hours, then start blowing warm. If you stop the truck, turn it off, then cycle the key 5 times quickly, it will work again for a couple hours again. Dealer couldn't find the problem.
  5. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    Edgrmndz and bigguns Thank this.
  6. driverdriver
    4,254
    5,284
    May 30, 2011
    Ok obviously you'll have to expand that second quote to read what I wrote.
    I'm not retyping it, lol.
  7. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Check the wiring at the high pressure switch. Start at the switch and work back, odds are there is a broken wire. I had the same issue a few weeks ago on my ProStar with Cummins, the wire was broken say two inches from the switch. That is located on the high pressure line, right up near the CAC/Condensor.
    And that switch, you do not need to evacuate the system to work on it if say it is bad, just plug and play. They run around $90 if it is bad, and they do at times fail. I think I have to install a new one every say year and a half two years.
    driverdriver Thanks this.
  8. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Hard to really tell what’s going on with the rest of the system using that cheap gauge that comes with the bottle of 134. Would like to have seen the video with dual gauges hooked up to see if there is a potential issue in the system that maybe be causing the system to not come on. Could be a blockage or a sensor. Who knows
  9. Justrucking2
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Been through this too... Find the Ambient Air Temperature sensor. It is usually buried in the harness at the driver side found under or very near the radiator, forward of the steering box. Dig that out, and get it into the open air. I rewired mine and placed it up at the drivers door and clipped to the windshield wiper cowl. The issues you described went away, I have had AC ever since moving that sensor.
    Here is a photo of what you are looking for... Get it into the fresh air away from as much heat as possible. Your dash board outdoor temp reading will also be a bit more accurate.
    And to you naysayers, look up Navistar Bodybuilder, the electrical schematics, trace that sensor, it is tied directly into the AC system. That is how I discovered this, chasing down an electrical issue with my AC. The same AC that has not worked in the first four years of owning this truck. Thousands upon thousands of dollars spent on this AC system. This is the first time it has worked, going on second year with ice cold AC. I now do all of my own AC work.
  10. Lazer
    Lazer Road Train Member
    1,849
    2,978
    Jan 22, 2017
    Is your defroster working proper? Not just blowing air, but is the compressor cycling proper?
  11. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    First, take that jumper wire off before you blow your system. You are forcing the compressor to say on full time. You have no protection from over pressure at all and it's a ticking time bomb. After that, the computer is the first tool I grab to see why it isn't engaging. When ac doesn't work in these you need someone properly qualified. You need a guy that knows how ac works, knows Internationals, knows electrical and electronics and knows how to use Diamond logic builder software. You have had a lot of work done there, I suggest you disconnect your batteries for a minute to allow everything to cold boot and retest.
