Air conditioning issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PaulMinternational, May 2, 2024.
  1. PaulMinternational
    PaulMinternational Road Train Member
    1,108
    5,831
    Aug 23, 2022
    Just talked to friend thats having air conditioner issues.
    Apparently his compressor started smoking.
    Replaced compressor and now the couch doesn't engage when he attempts to fill the system.
    If he hot wires the compressor it engages but immediately built excessive pressure.
    Any advice on what to look at for him
    2014 prostar
  3. kwswan
    kwswan Road Train Member
    2,049
    11,278
    Jul 26, 2009
    mcminnville,tn.
    Sounds like a blockage somewhere. Did he replace the dryer?
  4. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    Orifice tube?
  5. PaulMinternational
    1,108
    5,831
    Aug 23, 2022
    He said no blockage,
    Replaced dryer and some sensors under hood.
    I told him to start studying the wiring diagram. My thought is it should engage the clutch when you turn it on no matter what, once running those sensors or whatever they are should engage and disengage the clutch accordingly. If it doesn’t engage when you turn it on to me that means something is preventing those sensors under the hood from doing thier job. Problem has to be in the dash someplace. Does that make any sense to the mechanics out there?
  6. PaulMinternational
    1,108
    5,831
    Aug 23, 2022
    What the heck is an orrifice tube?
    Where would it be located?
  7. Mr Bob
    269
    84
    Mar 17, 2015
    if it has a big aluminum filter it probly has an orifice tube. if it has a black steel filter it probly does not have the tube. the tube should be changed anytime the system is open cause they plug up easily. if the compressor self destructed its better to replace the condenser too.
  8. 86scotty
    86scotty Road Train Member
    4,735
    13,002
    Aug 27, 2017
    Appalachia
    It's essentially like a little inline filter in one of the freon lines. Can be hard to find. Google it for your specific vehicle and you might find a pic or info.
  9. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Prostars are computer controlled, including the HVAC. There is a good chance the body controller detected either too high or too low of pressure and now has a latched code that will need Diamond Logic Builder software to clear to allow it to run again. Or, if the body controller is still detecting other faults that are active related to the ac, it will not power up the compressor. Power to the compressor comes from the body controller. Do not wire or power direct.
    Star Rider Thanks this.
