Air disc brakes.
Discussion in 'Ask An Owner Operator' started by flyingcow, Mar 31, 2013.
  1. flyingcow
    flyingcow Bobtail Member
    9
    Anybody been running them? Thoughts?
  3. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Ya man, good stuff, stops on a dime. Had them on the fleet tractors for years BUT very expensive to maintain so says the shop. No fade when wet, no howling when rusty, quick change on pads....but when the rotors went south? Hang on to your pocket. Steep cost, hard to find blah blah blah.........way more than a drum / shoe setup.
    Did away with them when going new power. Wanted the saftey but didn't want the cost......
  4. Wiseguywireless
    Wiseguywireless Road Train Member
    1,693
    802
    Dec 21, 2007
    Petoskey, MI
    I am running 6 way Disk on my truck, Good stopping. Pads lasting much longer than the drum brakes on my old truck. No one has had to replace them yet. in our trucks, so I have no Idea the cost diff verses time of use.
    chalupa Thanks this.
  5. flyingcow
    9
    Also should mention. If i do this, these will be on a new 3 axle trailer. I plan on ordering Intraxx axles with the air inflation system and maybe the air disc. Looking into a total set up from Hendrickson, with an extended warranty, maybe. Will be talking to reps monday. Also, i stop 15 times to load up per trip. i got 8+yrs out of my regular brakes, before replacing shoes. Approx 750,000 miles.
  6. Curly88
    Curly88 Light Load Member
    180
    228
    May 16, 2012
    Rexford Mt
    I got disk brakes on the steers on the kw I drive, good braking and the pads wear forever, but, both disks got a crack in them at around 700,xxx miles, after spending over $1800 without labor my boss was then told he could have gotten a used front axel with drum brakes put in for less $$. when the disks go bad or crack you have to change the whole bearing/hub assembly. Thats what kw said anyway.
  7. albhb3
    albhb3 Medium Load Member
    596
    279
    Nov 3, 2009
    have heard good things 40ft shorter stopping with just the front axle with them on 2015 there mandatory on all new trucks so prices should come down saw a pair with 90000 and the pads still looked brand new too.
  8. flyingcow
    9
    Thats one of the questions I have for Hendrickson, is the what if we have to change the rotors? Plus, i need to go see the local trailer shop that would be doing repairs. See what they say. All I've done is shoes on my milk trailer, in 750,000+/- miles. Low cost per mile. But if i might have to replace rotors in the same mileage? It'll be painful to justify it. I've run 20yrs, 100,000 miles a year haven't hit anybody yet. Maybe a moose or two, 1/2 dozen deer a few dogs, etc. But thats why I have my Aliarc moose bumper.
  9. Curly88
    180
    228
    May 16, 2012
    Rexford Mt
    With the little experience I've had with them I would say they're better ;more stoping power and less maintenance; but when you do have maintenance it costs a lot more. As far as the 40 ft shorter stopping distance? It might help you out in a pinch but its still up to the driver to keep the correct following distance. For example, somebody gets in a truck with disk brakes and figures out he can stop faster so his following distance will get shorter to, won't make it any safer. Just my opinion.:biggrin_255:
    starsonwindow Thanks this.
  10. Mattchu
    Mattchu Light Load Member
    149
    24
    Sep 9, 2012
    New Bedford, Ma
    do they stay cooler than drums?
  11. starsonwindow
    starsonwindow Medium Load Member
    569
    165
    Feb 2, 2012
    Phoenix, Arizona
    Nice Thread I will keep up with this. Thanks.
