Air Dryer is affecting My engine Idle
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Blind Driver, Apr 4, 2013.
  1. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Every time the air dryer farts, my engine idles rough for about 3-5 seconds, then smooths out.
    This is really annoying when I'm trying to sleep.
    This truck is having a power issue discussed elsewhere in the forum. It didn't use to do this. Engine idles rougher then before and this air dryer affecting the idle is strange.
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Nothing to do with the dryer, it's probably related to your power issue. When the compressor unloads, the dyer purges at the same time. The the compressor unloading changes the load on the engine. If you have another issue, it could affect the way the engine tries to compensate for that load change.
    How often does your dyer purge? When you're sleeping, your not using air, so it should hold pressure. It's common to lose some air with minor leaks, so you'll hear it purge once in a while, but it shouldn't happen too often.
    MJ1657 Thanks this.
  4. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    It might purge every 4 minutes or so. I can hear it hissing at times when the engine if off. I need to get the wrench turning guy to check it out.
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    If it is cycling that much you either have a major leak some where, or multiple little ones, or perhaps the dryer itself needs to be serviced.
  6. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    when my dryer did that, my fan clutch had a thousand tiny holes around it. had to build up air & turn truck off, but turn key in on position, soap fan hub area & wait 5-15 min & saw all the bubbles.
  7. Ridgeline
    22,736
    123,608
    Beside all the great advice given by the others, you may have a problem with the compressor itself.
    I had 700k on truck and around 670k the compressor was really hard on the engine (ISX). When it unloaded, the engine rpm's jumps up a little bit and then settled back to idle, not what you would expect. The compressor was removed, it was hard to turn (I mean very hard with a wrench) and had a lot of lateral movement on the shaft. Replaced it with a rebuilt one and the problem went away. I did replace the governor first to make sure that it wasn't the problem and then again with the new compressor and a new air dryer cart as a precaution.
    I have a truck sitting (just got it a month ago for next to nothing) which has oil on the air dryer outlet, so that compressor is going to be changed with a flush of the tanks and so on. I don't know when I will get to it, it may be a while but the oil tells me that the compressor needs new rings and valves. The previous owner's records noted that the oil consumption was high, but when dyno'ed the blowby was acceptable.
  8. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    Fix that leak bro... it's got to be annoying to others around you.
  9. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I am losing air after 2 hours. It's down to about 50 psi, then the air bags sometimes won't inflate. They eventually do, but I almost ran the trailer pin over the fifth wheel twice.
  10. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    and now one important quation: what engine? what year?
