Air dryer keeps dying out.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SpankingGT, Sep 4, 2013.
  1. SpankingGT
    SpankingGT Light Load Member
    253
    55
    Sep 9, 2010
    04 Columbia freightshaker!
    This is the third time this year I have to replace my air dryer. Is there a reason for this? Im also changing the air governor as well ( original not reman ) Is there something else I should look for that is causing this?
    Thank you in Advance!
  3. Heavyd
    Heavyd Road Train Member
    7,828
    6,277
    Feb 4, 2009
    What is the failure? What brand of dryer do you have?
  4. richardj87
    richardj87 Bobtail Member
    31
    9
    Aug 24, 2013
    dsm Iowa
    are you getting alot of oil discharge out of the dryer? could be that the Air Compressor is worn out oil will kill the insides of an Air Dryer
  5. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    Air dryer, compressor, governor all at the same time. Stop waising time screwing around and get back to making money.
  6. SpankingGT
    253
    55
    Sep 9, 2010
    Its Bendix brand. Today I replaced it and replaced the air governor. While I had to do a bypass to get the truck rolling, when installing the air dryer, I did see a lot of dirt with water. No oil though. Even the people at the freightshaker dealership were giving me hard time over replacing the air dryer under warranty.
    The failure is always the same, it will just let all air out from the purge valve.
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    may be compressor is old and throws oil in air system, so air dryer goes bad. check it and rebuild if necessery
  8. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    you need to replace unloader valve and o rings/gaskets.full of carbon build up.very common problem with series 60 (how did i know engine?lol!)bendix kits #5008557 unloader/#5008558 gaskets.when apart clean very well.good luck.
  9. Heavyd
    7,828
    6,277
    Feb 4, 2009
    Does the air dryer purge every 20-30 seconds, because it isn't supposed to. Probably wearing out prematurely. Something else is likely wrong. QualityTruck is reading my mind, good advice.
