Air dryer odd purge every 5-10 seconds
Discussion in 'Freightliner Forum' started by W Bench Farms, Nov 13, 2021.
  1. W Bench Farms
    W Bench Farms Light Load Member
    211
    351
    Oct 16, 2017
    95 FLD120. Having an odd issue with the air dryer. Dryer will sometimes purge every 5-10 seconds. It's not a normal purge, it's a long release of air. Doesn't do it all the time. Seems to do it more when it's cold. Compressor will run up to 120 and then it will sometimes do it. Air pressure does not drop like I have a leak, it stays right at 120. I thought the issue was in the dryer, and the compressor has some miles on it and was leaking some oil, so changed the compressor and dryer. Thought that fixed the problem then started again. Replaced the regulator as I thought it may have some oil in it making it stick when cold. Helped some, but still having the issue. Seems like it will do it when running down the highway, pressure goes down to cut in on the compressor, and when it runs back up the dryer will purge steadily. But like I said it's a long release of air, not the normal quick exhaust. Anyone have this happen?
  3. JonJon78
    JonJon78 Road Train Member
    7,248
    43,444
    Jul 1, 2018
    Maybe this will help...
  4. W Bench Farms
    211
    351
    Oct 16, 2017
    I think I narrowed down my problem. The compressor has a safety pop off valve on the side of the head. This seems to be the source of the air purge. Sounds just like the dryer. Finally caught it in action, as it never seems to do it when sitting at an idle, and happens randomly. Usually only when it's cold, or cruising down the highway. Going to pick up a replacement tomorrow. Hoping this will be the fix.
  5. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    It's the governor sticking that's causing the safety valve to pop, that is, if the pressure is also correspondingly high. Change the governor or lube that one up with a little silicone spray.
  6. W Bench Farms
    211
    351
    Oct 16, 2017
    I'm thinking the blow off pressure on the safety valve is low. Compressor, governor, and dryer are all new. It was doing this with the old set up. The safety is the only thing I did not change. Pressure gauge goes up to 120 and the safety will go off. Doesn't do it all the time. It's going off just under the cut off pressure on the governor as when it does this, the safety will purge several times then the dryer will purge, and then it's fine for a while.
  7. lilillill
    5,642
    13,472
    Nov 7, 2007
    The new compressor didn't come with a new safety valve? If it's popping off at 120, then yep, time to replace it.
  8. W Bench Farms
    211
    351
    Oct 16, 2017
    New compressor didn't come with one, and I should have replaced it, but it was a Sunday when I had it off so no luck getting one. After doing some research, Bendix makes 2 different versions. A 1/2" NPT 250 psi and a 1/4" NPT 250 psi with a bushing. Someone had replaced this one before with a 150psi. Hoping this is the issue.
    lilillill Thanks this.
  9. W Bench Farms
    211
    351
    Oct 16, 2017
    New safety pop off valve did the trick. Ran all day today and all is well.
    lilillill and Crude Truckin' Thank this.
