Air dryer pop off valve leaking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OldeSkool, Sep 7, 2022.
  1. OldeSkool
    OldeSkool Road Train Member
    2,149
    7,150
    Jul 17, 2018
    New Hampshire
    I have an air leak wear my finger is pointing, which I assume is the pop off valve. Sometimes when it blows off it stops leaking, but a lot of the time it does. Can something be replaced or is the whole dryer bad?
  3. OldeSkool
    2,149
    7,150
    Jul 17, 2018
    New Hampshire
  4. bad-luck
    bad-luck Road Train Member
    3,498
    6,472
    Nov 16, 2013
    Baltimore, Maryland
    No picture posted. But yes, the purge valve can be replaced.
    Big Road Skateboard Thanks this.
  5. OldeSkool
    2,149
    7,150
    Jul 17, 2018
    New Hampshire
    Ok I think I got it posted now.
  6. Mr Bob
    Mr Bob Light Load Member
    272
    84
    Mar 17, 2015
    you need to get the kit. make sure there is no air in the system.
  7. AModelCat
    166,468
    Most cases the valve spool gets gunked up and sticks.
  8. Antinomian
    Antinomian Road Train Member
    2,213
    3,527
    Feb 17, 2013
    Good thing it's failing now. You'll have a fresh one for the winter. That's when they usually fail.
    Might as well change the desiccator cartridge in the dryer while you're at it.
  9. SmallPackage
    5,877
    18,864
    Dec 20, 2019
    Marion Texas
    Those things really shouldn’t go bad if the system is functioning efficient and kept clean. It’s always a good idea to spray some brake clean through them a few times a year. The dirt that sticks to them on the outside is just as bad as the oil from inside.
    How many guys actually think to scrub them clean with dawn or degreaser when washing the truck or at least hit them with water out a garden hose to keep dirt and grease buildup at minimum? Kinda like washing out the brake dust from the drums and shoes, hardly ever done till replacement time.
    OldeSkool Thanks this.
  10. OldeSkool
    2,149
    7,150
    Jul 17, 2018
    New Hampshire
    Well I replaced it. It was nasty corroded up in there. Broke the old one all up getting it out. It still leaks despite the fact I’ve took it back out and cleaned it as well as I can so I’m replacing the whole dryer. Went from $65 to $612 lol. At least I can do it myself.
  11. Mr Bob
    272
    84
    Mar 17, 2015
    stop throwing money at it and find the cause. does your compressor unload when it comes up to purge? pull off the compressor hose and find out.
