Air dryer safety valve popping off when cold
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by SemperFiServices, Nov 13, 2019.
  1. SemperFiServices
    SemperFiServices Medium Load Member
    379
    233
    Jan 29, 2013
    Indianapolis, IN
    Hey y'all, I've researched as much as I could and I'm still lost. I have a Bendix AD-IS in this Pro Star I just bought- still working out the bugs Knight didn't. O bought the truck a couple months ago when it was warm. First time it dropped into the low 40's, the air pressure would build to about 140 psi or so on the gauges, and the safety valve would pop, air pressure would drop to about 70 psi, and build back up.
    Last night, I hunkered down under 2 comforters and shut her down as it hit 16° in upstate NY. I started the truck this morning, and it must've popped off about a good 8-10 times until it finally warmed up enough and purged at 120 psi like it's supposed to.
    Any idea why the cold is causing the air drier to build up too much pressure?
  3. tommygun58
    tommygun58 Light Load Member
    88
    61
    Sep 22, 2015
    East Texas
    Gov. May be bad? Just a guess
    PE_T and SemperFiServices Thank this.
  4. Cat sdp
    Cat sdp . .
    21,356
    76,678
    Apr 8, 2012
    Orion's Belt
    Cartridge is probably full of crap and heat for the air drier isn’t working...
  5. Goodysnap
    Goodysnap Road Train Member
    3,814
    9,299
    Jul 12, 2017
    I would say your dryer was never serviced, the desiccant is oversaturated and you have moisture floating in the system. Drain the tanks thoroughly while above freezing. Replace the dryer complete with new, and keep the filter changed annually or more often for extreme service.
    PE_T, SemperFiServices and Wheeljack Thank this.
  6. jed222
    jed222 Bobtail Member
    11
    5
    Nov 14, 2019
    Sounds like the filter is saturated service the dryer check the complete reman pricing sometime they aren’t much more that a filter and purge kit then it’s just r&r
    SemperFiServices Thanks this.
  7. SemperFiServices
    379
    233
    Jan 29, 2013
    Indianapolis, IN
    Thanks everyone for the responses. I think I might just replace the whole thing with an aftermarket unit from Ebay or Amazon for under $150. After 500,000 miles it couldn't hurt.
  8. Goodysnap
    3,814
    9,299
    Jul 12, 2017
    I would be leery of any new dryer bought on Amazon or EBay for that price. You may be buying a expensive boat anchor. I would shop around and find the best deal on a new bendix at a local parts house you know.
    pushbroom and spsauerland Thank this.
  9. Final Drive
    Final Drive Road Train Member
    1,573
    2,507
    Jan 21, 2015
    Op
    When all is said and done, learn how to bypass your dryer. I had to bypass mine at 17 below..
  10. Rideandrepair
    17,605
    57,000
    Aug 8, 2015
    Truckpro has Armada AD9 $190
  11. SemperFiServices
    379
    233
    Jan 29, 2013
    Indianapolis, IN
    This is an ADIS model, nothing it's ever easy for me. I did replace the desiccant filter and the darn thing is buzzing away even with 185° water temp, oil at 220°, but it's 18° outside. I need to check the heater, because I think that's the issue. But these stupid internationals have the worst fuse box set up ever! The diagram is clearly labeled, but does not at all reflect what the heck is actually installed in the truck.
