Air Dryer
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Eboogey, Nov 6, 2020.
  1. Eboogey
    Eboogey Bobtail Member
    10
    4
    Nov 4, 2020
    Anybody familiar with Niuparts.com?
    I called the dealer for price on an air dryer, $718.00. Then I look on the internet for an aftermarket dryer and I come across on from these guys for $125.00. They are out of Canada, should I be wary of this, found an aftermarket dryer on two other sites for $612.00.
  3. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    I sure as shooting wouldn't buy one for 125$ when everything else is closer to 600. And once I'm at 600 id probably just spring for the dealer price
    Eboogey and Rideandrepair Thank this.
  4. Rideandrepair
    17,559
    56,884
    Aug 8, 2015
    You got my attention. I looked it up, for sale through amazon. I wouldn’t hesitate to get it. Dealers are hit and miss on parts. Reviews are 5 out of 5. Aftermarket is so huge for Truck parts. Lots of competition. Take advantage of it.
    Eboogey Thanks this.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I usually get my AD-9 dryer from my local Freightliner dealer, $179 exchange for a reman.
    AModelCat, Eboogey and Rideandrepair Thank this.
  6. Idahojoel
    Idahojoel Light Load Member
    63
    48
    Jan 17, 2018
    Phoenix Arizona
    What type air dryer? I just replaced my ad9 for $150 took 20 min
    Rideandrepair Thanks this.
  7. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    AD9 is like 125 around here
  8. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    Dang I didn't realize they were that reasonable
  9. MRMTRANS
    MRMTRANS Medium Load Member
    407
    440
    Apr 28, 2015
    I just saw on sale at Transwest Freightliner in Colorado 1 hour ago an AD9 reman cost $179 (If I remember right), and new cost approximately $275-I think. Eboogey, I would check as to whether the $125 is remanned or new. Probably remanned. Or there is a catch, like maybe it doesn't include the incandescent cartridge,or it isn't wired, or original molds that were manufactured a little out of spec that the maker sluffs off onto aftermarket dealers. If it fits, and it plugs right in, and you don't have to do or buy a cartridge or wire it, I think I would give it try. The worst case is that connect the 2 lines at the drier real quick and fix it right away again. If the purge valve leaks where it seats to the housing, I would think you might could install a slightly larger o-ring/seal and use it again. Hell, where my AD9 is located, I can change it in 15 minutes at a truck stop parking lot.
  10. MRMTRANS
    407
    440
    Apr 28, 2015
    Keep in mind, there are businesses out there nowadays that are in need of revenue income and are maybe unloading inventory cheap and pocketing the cash before they file for bankruptcy.
    Rideandrepair and little cat 500 Thank this.
  11. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Just make sure it's a Bendix and your good.
