Air dryer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ColumbiaBoB, Jan 13, 2025.
  1. ColumbiaBoB
    ColumbiaBoB Light Load Member
    190
    21
    May 3, 2011
    Des Moines, IA
    I have wabco air dryer and on the bottom next to the purge valve there is another let's call it valve [not sure what it is called] it's leaking a bit of air, called dealer and they want to sell me $1000 new air dryer, they say that part can't be bought by itself, any idea what's it called and is it possible to buy a new part or rebuild it with parts, ty 20250111_144840.jpg 20250111_144821~2.jpg
  3. Big Road Skateboard
    7,096
    40,246
    May 2, 2021
  4. ColumbiaBoB
    190
    21
    May 3, 2011
    Des Moines, IA
    Do you know is it possible to buy it new or rebuild it
  5. Ridgeline
    22,720
    123,295
    That's right, it is a turbo valve, rebuildable!!
    The air dryer is a system saver 1200 plus series air dryer with multi-circuit protection. So, it depends on the model and serial number of the unit, there are four kits (inexpensive) that include all the parts needed. The cost should be around $50 but you need the right kit.
    It is important you take it apart carefully, there is a spring in there and reassemble it like it came out. You have to use Oring lube, not grease, I had several kits that did not have it in the package so we used Parker Super Oring lube - $20 per tube, you just need a little bit so save it for next time.
