air dyer keeps on purging
Discussion in 'Volvo Forum' started by sikwpn, Apr 22, 2014.
  1. sikwpn
    sikwpn Bobtail Member
    15
    Aug 28, 2013
    Hi guys,
    i got a volvo 2004 fh12 500hp, just install new brand wabco aircompressor and air dyer because it wasnt building air and now im having problem with my air dyer keeps purging as it wont shut of my aircompressor and keeps building air ?? :biggrin_25518:
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Replace air GOV.
  4. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Airlines to the governor could be blocked or hooked up wrong, air governor could be bad. That's where I'd start. Could be luck of the draw and you just got a faulty compressor, but check the simple stuff first.
  5. sikwpn
    15
    Aug 28, 2013
    it doesnt have 1, i know on the volvo fh12 version 1 has it on the side near the battery tray, mine is electronic and its bolted on the side the air dyer act like 1 unit but can be unbolted..
  6. supernova
    supernova Bobtail Member
    38
    18
    Jan 11, 2014
    Calgary AB
    I agree, replace the air governor.
  7. eeb
    731
    268
    Mar 24, 2013
    I hadn't heard of an electronic air gov. Might have to take it to a dealer or whoever did the work before. Maybe they forgot a piece?:biggrin_25517:
  8. sikwpn
    15
    Aug 28, 2013
    http://rolie.en.alibaba.com/product...O_air_dryer_20884103_4324251010_20466522.html
    thats the same air dyer i have on my truck which doesnt have an separated air governor, can i add 1 in? or is it my ecu needs programing ??
    and this is the unit thats bolts on the side of the air dyer, i dont know whats its call but i know its some kinda electronic valves
    http://quattroker.hu/pl/webshop/00051086-/cikk/81147/
    i have check the air line from the air dyer to compressor which is still good, how i knew cos i blew work shop air into it.. run outta ideas, some saying it could be my wet tank, clutch fan.........
  9. Gordon A
    Gordon A Medium Load Member
    384
    345
    Jul 22, 2013
    ECU has nothing to do with air governor. Air governor is mechanical. Also the purge valve may be stuck or have crud in it. Did you change the Air dryer filter? Don't forget to drain your air tanks at least once a day . Install a pull cable if there is not one on it now. My air governor cost about $18 bucks. Not sure which on your engine needs.
  10. jabekins
    jabekins Bobtail Member
    37
    17
    Apr 16, 2014
    Warrenville,IL
    The gov controls the air pressure it might be in the dryer it self that is causing it to purge you need to take it to the shop or risk losing the compressor.
  11. bad-luck
    bad-luck Road Train Member
    3,450
    6,366
    Nov 16, 2013
    Baltimore, Maryland
    When you say it keeps purging do you mean air is constantly coming out of the purge valve? also if you replace both the air dryer and the air compressor you should have replaced the air governor. Air governor only costs about $46
