Air horn will not stop blowing
Discussion in 'Volvo Forum' started by habfleet, Jan 6, 2015.
  1. habfleet
    habfleet Light Load Member
    163
    23
    Feb 5, 2012
    elwood nj
    Have a Volvo VN 2005 ISX when ttruck airs up air will not stop blowing.I ve jiggled the cover on the steering wheel no success. Check wire to air/solenoid on crossm member has continuos power. Volvo dealer ttells me the entire air bag module has to replaced and then programed with Volvo computer. Is this B S or what . I know there is a srs contact reel under the air bag. Is this what the probally really is ?? Or is there a contact ring for the air horn. Thanks in advance
  3. skyviper73
    skyviper73 Heavy Load Member
    735
    589
    Feb 17, 2012
    Centennial, CO
    Your HORN blows constantly? Find the horn, disconnect the air line to it, even if you have to cut it, and clamp the line off with vice grips. Or am I misunderstanding the problem?
    25(2)+2 Thanks this.
  4. Runamukinfl
    Runamukinfl Light Load Member
    61
    12
    Dec 6, 2013
    Tampa Fla
    city horn or airhorn..sounds like city horn thats suxs..see if there is a fuse..
  5. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    No its the air horn which is activated by the center of the steering wheel. looking to find out what needs to be replaced in the steering wheel to correct problem
  6. Runamukinfl
    61
    12
    Dec 6, 2013
    Tampa Fla
    sorry i dunno now..
  7. 201
    201 Road Train Member
    12,796
    26,336
    Apr 16, 2014
    high plains colorado
    Just the thing for going through downtown Chicago. Seriously, the horn button on the steering wheel must be shorting out, from all the coffee or soda (or worse) being spilled, or just worn. If it's not the button, there must be an electric to air relay under the dash or on the firewall that's stuck.
  8. Roadrealtor
    Roadrealtor Road Train Member
    1,061
    1,070
    Aug 7, 2010
    Fort Myers, FL
    Hanging the laundry on the pull chord???
  9. lfod14
    lfod14 Road Train Member
    1,178
    689
    Jan 9, 2014
    That's what its for isn't it? When its dry it gets lighter and the horn stops blowing which is of course how you know its done.
