air horn
Discussion in 'Ask An Owner Operator' started by Izzy MG, May 3, 2013.
  1. Izzy MG
    Izzy MG Bobtail Member
    my air horn is not working on volvo 2005
  3. cuzzin it
    cuzzin it Road Train Member
    3,648
    13,131
    Jan 19, 2008
    Berea, KY
    use your finger :biggrin_25516:
    EZX1100 and MoGooder Thank this.
  4. dschmidt201
    dschmidt201 Light Load Member
    289
    109
    Jan 6, 2012
    Chicago
    If you turn the air cutoff govener up the air horn will be louder
  5. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Apply more cow bell.
    GoneButNotForgotten Thanks this.
  6. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Is air reaching the horn?
  7. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    check the air line on the vavle when you pull it do you have air coming out. is it good amount of air....if you do bad bell most likely or dirty....run water into the bell with some pressure
  8. jlawall
    jlawall Light Load Member
    63
    15
    Jan 29, 2011
    wapwallopen pa
  9. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    If the truck is off do you hear the valve click when you hit the button?
  10. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    :biggrin_25526:
  11. StayBusyTrucker
    StayBusyTrucker Medium Load Member
    492
    150
    Mar 25, 2013
    The air horn on the 2013 international is electronic :(
