Air leak- any help?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 13letter, Dec 19, 2008.
  1. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    You'd hear the check valve going off.
    Do you by chance have one of those automatic grease systems on your truck? Or possible a filtration system for the oil?
  3. sleepless nights
    sleepless nights Light Load Member
    69
    14
    Jul 26, 2008
    Canada
    There should be a small line that comes off your govenor and runs down to your air drier. Spray it with your soapy water from one end to the other it may be leaking and if it is it will only leak when the gov send's the signal to the drier to purge when the gov reaches high high limit until it bleeds down to low limit where the comp kick back in. It only has to leak the air out of that small line down to 90-110 psi what ever your low limit is and then it will start the cycle all over again. Thats why it is probaly purging so often. And when you shut the engine off it leaks down to where the gov hits low limit and then it should quit, thats why it dosen't leak when the engine is shut off. Hope this is the problem because it will be a easy fix for you.
  4. AgLaw
    AgLaw Light Load Member
    61
    34
    Jun 27, 2008
    Wharton, Texas
    Which Bendix AD-? They made plenty--AD-1, AD-2, AD-4, AD-9, AD-SP, AD-IP, & AD-IS. The latter four are the most prevalent these days. Does the dryer have a spin-on cartridge? If so, it would be one of the latter three mentioned. The AD-IS, a self-contained (non-integrated) unit, is a spin-on style and has a purge reservoir that looks like an old vacuum brake booster attached to it. The AD-SP is the only one that I know of from Bendix that requires the protected check valve to be installed in the secondary tank.
  5. Rock hauler
    Rock hauler Light Load Member
    264
    54
    Nov 26, 2008
    Deridder La.
    on that int mine had two lines comeing off the gov. one to the airdryier one went into the dash. we tried bypassing the dryier but it kept building air until reg valve on compressor poped off. im sure theres away to do it but i just put on another dryier
  6. IH Truck Guy
    4,947
    57,445
    Mar 2, 2008
    Purgatory
    By-pass the air dryer and your problem will magically disappear.:yes2557:
  7. droy
    droy Heavy Load Member
    828
    160
    Jun 11, 2008
    Iowa, LA
    Sleepless nights post reminded me of a problem another KW owner from our terminal had; the stainless braided line from the compressor, (main line), connected to a woven, wire braid line behind the engine. This line looked good from the outside, but when he hit it with the soapy water, it turned into a bubble factory. The inner rubber hose started falling apart, losing a lot of air, and plugging up the air dryer with small rubber bits.
  8. Lilbit
    Lilbit Road Train Member
    16,583
    12,233
    Aug 4, 2008
    Let me check my logbook
    Definte possibility there. That has happened to my hubby's truck (company truck that is) twice.
  9. AgLaw
    61
    34
    Jun 27, 2008
    Wharton, Texas
    No you wouldn't. The check valve is simply an internal "one-way" valve in the air system plumbing--not a "pop off" safety valve. The special check valve I'm speaking of is a "one-way" with limited "contraflow". The leak would be strictly internal of the system and you wouldn't hear a thing.
    Good question though. Something else to consider.
  10. Les2
    5,150
    2,288
    Jul 25, 2008
    Sorry AG thought you was talking about the pop off valve. If it was the one way valve you'd think the whole system would leak down not just the secondary side?
  11. Brickhauler
    Brickhauler Medium Load Member
    411
    142
    Oct 1, 2008
    Elizabeth CO
    Two things come to mind. My other truck fan hub developed an air leak but only when the engine was running so when you tried turning the key on with out starting the truck to check for a leak there was none, as soon as the engine started the leak started too.
    The other thing is I have seen is the spring brake chamber leak internally and cause the problem you describe. If you disconnect the application side hose from the chamber and then release the brakes, if the chamber is bad, air will leak out of the fitting where you unhooked the hose causing the pressure loss. The truck brakes will still act normal except for the air loss while going down the road.
