Air leak at splitter
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kwforage, Feb 11, 2020.
  1. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I have a RTLO18913 that will leak air for a second at the shift knob when splitting down form the high side to the low side. It still shifts fine, everything seems normal except this little spit of air everytime I split down. Any ideas?
  3. AModelCat
    165,058
    Did it just start doing it?
    The valve on the stick is meant to exhaust air from the cylinders on the transmission IIRC. Could just be normal operation.
  4. kwforage
    1,047
    472
    Jun 3, 2007
    Wisconsin
    Just started, it's not the normal exhaust air leak.
  5. Deere hunter
    2,170
    10,517
    Aug 5, 2017
    Shallowater Texas
    Mine does something similar to that every once in a while so when I park for the night I just sprayed WD-40 in all the little cracks wipe it down and go to bed next morning no leak!
  6. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Likely you just have an o-ring that's leaking a little. Could be cut or just dry. Simple enough to take the top off and replace and lube everything up. Or just leave it be. Mine leaks pretty much constantly when the splitter is back. I haven't bothered to take it apart, I just primarily leave the splitter forward
  7. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,082
    Sep 24, 2019
    Raleigh, NC
    rebuild kits are fairly cheap, but honestly just a good cleaning and lub on the springs will work wonders
