Air leak behind daah
Discussion in 'Mack Forum' started by mack666, Mar 23, 2019.
  1. mack666
    mack666 Bobtail Member
    I have a 95 Mack ch
    Air leaks behind dash until air pressure drops to 60 pounds then it stops leaking.
    I’ve removed all front panels on dash but can’t feel where the air is coming from.
    Also not on the fire wall.
    Any ideas?
  2. Razorwyr
    Razorwyr Road Train Member
    2,176
    2,518
    Jul 27, 2010
    Meridian, Mississippi
    Sounds like it's in the brake system. Hits 60 psi and brakes lock the springs, cutting off the air flow to the brakes so it stops leaking.
  • Draft saved Draft deleted
