Air leak issue
Discussion in 'Volvo Forum' started by bilyonfire, May 26, 2020.
  1. bilyonfire
    bilyonfire Bobtail Member
    Hi everyone, I have 2014 Volvo D13 ... Truck is losing air while I'm driving without pushing the service brake(Pressure in the F is leaking way faster then in the R) ...for example compressor pumps at 120PSI i hear the sneeze and after like 10 minutes my F gauge is showing 90 and the compressor starts pumping again while the R stays at 120! I already took it to couple shops replaced gauge sensors and purge valve kit and checked for leaks and they keep telling me there's is no leak!When truck is parked its not losing the air! Please help
    Trucking Jobs in 30 seconds
  3. jlawall
    jlawall Light Load Member
    57
    8
    Jan 29, 2011
    wapwallopen pa
  4. jlawall
    57
    8
    Jan 29, 2011
    wapwallopen pa
    Have you tried checking with truck off-key on around fan clutch connections? No air to it when key off only with key on after probably 5 minutes after key on. you've probably noticed your fan is engaged for around 5 minutes after startup then shuts off. At that point you would have air leak in that system if that 's the problem.
  5. Dave124
    Dave124 Light Load Member
    54
    31
    Mar 11, 2019
    I had/have a bad fitting on the line that tee’s in from the transmission. But you can here it leak with key off. I wonder if it is just your suspension / air bags while driving functioning (levelling valve on and off) since you can’t hear anything with key off?
  6. 05vnl670
    05vnl670 Light Load Member
    155
    54
    Feb 17, 2013
    I had a same problem. Mine air fitting on the fan was leaking, replaced with new fitting and the problem went away.
    Built up air pressure, make sure you climate controls are in off position and then turn the key on with truck not running. I was able to hear air leak from the fitting.
  7. devedo
    devedo Light Load Member
    103
    36
    Aug 11, 2015
    Driver's side of the engine a little ways behind the fuel filter is a module that has some electrical connectors and a 1/4 air supply line (yellow or purple color) that has been prone to leak.
    There's also an air manifold mounted to the drivers side frame near the transmission with about 7 different sized air lines going to it that's notorious for leaking.
  8. Rob100100
    Rob100100 Light Load Member
    171
    94
    Mar 5, 2016
    Bad levelling valve, air leak from airbag or connectors, many things it could be. Get a plastic spray bottle one third filled with soap and your butt under your tractor and start looking neighbour.
  • Draft saved Draft deleted
