Air leak?
Discussion in 'Questions From New Drivers' started by DAX_, Dec 29, 2019.
  1. DAX_
    DAX_ Medium Load Member
    603
    505
    Sep 4, 2017
    So for the past two days when I push in the trailer breaks, I hear a hissing noise that usually goes Away but this time it stayed during the whole trip.
    So I pick up an empty trailer and head to the
    truck stop. Still the same noise but as im setting up my backing the noise gets louder and more intense. The air pressure Guage you so low they dropped to below 50 as I was backing up. Once I backed up and and fully straightened the wheel and trailer the air pressure went back up
    Is this an air leak issue
  3. Deere hunter
    2,182
    10,683
    Aug 5, 2017
    Shallowater Texas
    Sounds like your valve assembly in the dash is that where it’s leaking in the dash???
  4. The Dirty Trucker
    The Dirty Trucker Bobtail Member
    5
    6
    Dec 29, 2019
    Sounds like you have a damaged air cylinder the automatic transmission your driving or theres a hole in the air line to your splitter
  5. HillbillyDeluxeTruck
    5,961
    30,523
    Mar 3, 2013
    San Antone
    This is stuff they teach or are supposed to teach in cdl school.
    Do you not know how to diagnose an air leak? Do you not know how to do an in cab air brake test? What are the rules/guidelines for air pressure? How many lpsi can a system in a combination vehicle drop in 60 seconds?
  6. Numb
    Numb Crusty Curmudgeon
    4,357
    10,361
    Jan 30, 2012
    Charlotte, N.Carolina
    you hear air leaking.
    the air gauge drops.
    nope, no air leak. o_O
  7. rbrtwbstr
    rbrtwbstr Road Train Member
    3,403
    7,951
    Jul 11, 2012
    in the bush somewhere
    Well, at least the OP realizes there's an issue and is asking. Gotta give him/her credit for that.
    But, yeah they should have taught such things in school.
    OP, did you even attempt to locate the issue? Try releasing just the tractor brakes, make sure the trailer brakes are set. Does the air leak? If it does, the problem lies in the truck. If not, set the tractor brakes and release the trailer. If it leaks, then it's likely the trailer.
    Or try shutting the truck off, block the wheels so it don't roll away, and release the brakes. Then get out and listen for air hissing outside.
    DAX_ Thanks this.
  8. DAX_
    603
    505
    Sep 4, 2017
    How long would this usually take to fix. And how does this type of damage usually happen. I feel like it could have been due to a truck hitting me a couple weeks ago
  9. DAX_
    603
    505
    Sep 4, 2017
    Thank you. It only makes the noise when the trailer breaks are released. The tricky thing is the fact that it has a done it with two different trailers
  10. HillbillyDeluxeTruck
    5,961
    30,523
    Mar 3, 2013
    San Antone
    You cant evdn figure out where the air leak is, yet want us to tell you how long it'll take to fix it?
    Okay. Between 5min and 20 hours.
    starmac, copperdome and spyder7723 Thank this.
  11. DAX_
    603
    505
    Sep 4, 2017
    I didn't ask you nor have I quoted you in this thread up until now. There's a reason for that. You can exit.
