Air leaking
Discussion in 'Peterbilt Forum' started by Sodapop, May 11, 2024.
  1. Sodapop
    Sodapop Light Load Member
    93
    7
    Mar 19, 2010
    Blytheville,Ar
    2004 379 Pete, When i apply the brakes , I hear air coming from behind the panel at the fire wall...Was told there are 2 valves, switches there..Anyone with more detail and possible part #'s Thank you
  3. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    Check and see if your brake lights are working. Your air over electric switch probably blew into two pieces.
  4. Sodapop
    93
    7
    Mar 19, 2010
    Blytheville,Ar
    there working,...when i pull trailer valvedown, or apply brakes from feet pedal I hear the air from firewall, behind that panel..Brakes doesnt seem as good
  5. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    Could be the airline back there going to the brake application gauge also. You're just gonna have to pull that panel and look.
    5UG, beastr123 and Sodapop Thank this.
