Air Pressure Drop
Discussion in 'Questions From New Drivers' started by farmerjohn64, Jul 11, 2020.
  1. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
    Hi,
    I picked up a lumber load a few days ago and after I got loaded and went to put it in drive my air pressure dropped from 120 all the way to the red almost immediately and I have no idea why; the guy who loaded me walked over after I finally made it to the scale, unintentionally holding people up for about 5 minutes and I explained to him what was going on, but then he cut me off and said he knew “exactly” what’s going on and he’s complained to Western’s corporate office about this, said he’s had “nothing but trouble” from us guys; he didn’t grace me with his knowledge on the subject and the problem subsided once I pulled up to the final securement area by only dropping 20 psi and then back to normal (I fooled around with it until it stayed at 120).
    Anyone have any clue what might’ve happened? It’s never done this before and the only thing that was different is the presence of substantial debris such as wood chips.
    Best regards, John
  3. SoulScream84
    3,458
    26,545
    Mar 21, 2020
    All I can think of is that during your loading process all the air in your bags was gone, and once you supplied air again it took a minute to fill the system. I highly doubt a forklift operator knows enough about anything to supply any knowledge, and if he did call the company about a "problem" they probably told him to pound sand.
  4. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
    It did that about 3 times in a row, I released the brakes and reved the engine to build the air pressure back up each time; that was weird as hell,
    Rideandrepair Thanks this.
  5. kemosabi49
    10,977
    47,918
    Jan 13, 2013
    SW Arkansas
    Does your trailer dump the air bags when you pull the red knob and set the trailer brakes? If so then your bags and trailer air tanks have to fill back up when you release the brakes. Stop setting the trailer brakes while getting loaded.
  6. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
    Hmm I’m not sure, I’ll have to check that, but it was the red valve (trailer brake) that kept giving me problems; the secondary air tank
  7. Qbf594
    Qbf594 Road Train Member
    1,642
    8,715
    Aug 15, 2019
    Southern Canadian annex, NY
    The forklift guy is likely a douchebag.
    Get the rpms to around 1300 or it'll take forever.
    Don't pull the red unless you're dropping a trailer or parked on Mt Everest. That's how I do it....
  8. AModelCat
    164,691
    Yeah if you've got to charge an empty trailer reservoir you'll easily lose 40-50 PSI in the matter of about 5 seconds.
    Rideandrepair and farmerjohn64 Thank this.
  9. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
    Yeah he did meet the DOT requirement of douchebag; I never heard of only setting one of your brakes, but I’ll try that for now on
    Rideandrepair and D.Tibbitt Thank this.
  10. Qbf594
    1,642
    8,715
    Aug 15, 2019
    Wait. Wyoming. Saratoga?
    farmerjohn64 Thanks this.
  11. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
    That’s about how fast that sucker went down
