air pressure loss?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cumminsISB, Feb 25, 2015.
  1. cumminsISB
    cumminsISB Light Load Member
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    Truck has an air pressure gauge with 2 needles. One red (rear) one green (front). My problem is I am losing air pressure on the rear (red) more than the green. Will cut truck off with both needles at 120 psi. Look at the gauges after an hour and the green one is reading 100-110 psi, but the red one will be on 60 psi😱. I have replaced all air lines on compressor and air dryer. Where do I need to start looking. Cannot hear any air leaks, you would think with it leaking down that fast I would hear it. Help?
  3. Hammer166
    7,620
    27,889
    Aug 18, 2007
    ~8600+' and loving it!
    It would help if you can figure out which systems each tank feeds. But what you are describing is commonly caused by a leaking airbag on the main or cab suspension. Soapy water sprayed around the base of the bags between the bladder and piston will find that.
    DoneYourWay and cumminsISB Thank this.
  4. Skater
    Skater Bobtail Member
    36
    18
    Jan 20, 2015
    Atlanta, GA
    Ditto to above. Also check for a leaking drain valve. Happened to me before
    cumminsISB Thanks this.
  5. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    I would spray (with soapy water) every possible air line fitting and all airbags, using this method you are destined to find the leak.
  6. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    Thinking the red is the primary for the brakes system. Kids bubbles and a squirt bottle work good for finding leaks. They can be anywhere-including behind dash-leveling valve-air seat valve-air horn valve-etc. etc. If you step on brakes and the red needle moves-start with the brake system but both are tyied together.
  7. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    thanks guys. Found a brake chamber leaking on my trailer but don't think that is the only leak.
  8. Hammer166
    7,620
    27,889
    Aug 18, 2007
    Guess I made the mistake of assuming no trailer... check the gladhand with the soapy water, too.
    DoneYourWay and Cetane+ Thank this.
  9. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    Found another leak in one of the air bag lines. Will fix the 2 leaks I have found so far then check under cab.
  10. boneebone
    2,297
    2,372
    Mar 13, 2009
    The Foot Brake Valve that's mounted on the Driver's side Firewall under the hood has a lot of Air Lines passing through the Firewall. It is common to have leaks there too. The Engine Fan Hub Seal could also could be leaking.
    DoneYourWay Thanks this.
  11. xsetra
    xsetra Road Train Member
    5,199
    7,151
    Aug 21, 2011
    Leveling valves. Cab, truck chassis and trailer.
