Air pressure not building up
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BlackKw900, Feb 28, 2021.
  1. BlackKw900
    BlackKw900 Bobtail Member
    20
    7
    Feb 12, 2021
    Good morning guys
    I’m in need of help I have a w900 that it’s not building air pressure, I just replace the air compressor and governor and give it a go and still not building air, so next took air dryer apart to clean it up and still not the same, I have check for air leaks and couldn’t find any.
    Thanks for help
  3. xsetra
    xsetra Road Train Member
    5,212
    7,163
    Aug 21, 2011
    What motor?
    Did you remove the outlet from compressor or inlet hose to air dryer and check for air pressure?
  4. baha
    baha Road Train Member
    4,136
    2,837
    Jul 25, 2013
    ga
    If you can't hear air leaking from any place, pull line off back of air comp. and ck for air coming out of it, if nothing replace gov. with new not rebuilt one?
  5. Deere hunter
    2,681
    16,097
    Aug 5, 2017
    Shallowater Texas
    Check and see if you have a one-way valve stuck they do that from time to time.
  6. BlackKw900
    20
    7
    Feb 12, 2021
    Detroit 60 series, yes air is coming out of compressor
  7. BlackKw900
    20
    7
    Feb 12, 2021
    Check for air leaks and couldn’t find any, already replace compressor and brand new gov
  8. BlackKw900
    20
    7
    Feb 12, 2021
    Hey Deere hunter, how do I do that and where can I find it?
    Thanks
  9. Deere hunter
    2,681
    16,097
    Aug 5, 2017
    Shallowater Texas
    You’ll have a one-way valve into your primary tank that way the air goes into the tank but won’t come back out after you shut the truck off. they stick some are down by the tank some ate right at the compressor.
  10. Deere hunter
    2,681
    16,097
    Aug 5, 2017
    Shallowater Texas
    Lots of times you can free them up with WD-40 but it’s probably better just to replace it if that’s your problem
  11. Deere hunter
    2,681
    16,097
    Aug 5, 2017
    Shallowater Texas
    On my Peterbilt they are on the tanks right underneath the doors. I don’t know what you have
