Air pressure not building.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by stylez80Nine, Aug 27, 2024.
  1. stylez80Nine
    stylez80Nine Light Load Member
    185
    58
    Dec 2, 2018
    Hello everyone I have a 1999 Freight liner Fld 120 with n14 Cummins. My air pressure it’s not building unless I red line my RPMS please send me the right directions. Thanks in advance. And when I drive I lose air but it goes back up when driving.
  3. stylez80Nine
    185
    58
    Dec 2, 2018
  4. Big Road Skateboard
    7,209
    40,984
    May 2, 2021
    You either have major air leaks, drier issues, of compressor issues.
    You need to plumb in shop air and see if it builds, and see where air leaks are.
    You can pull the discharge line off the compressor and see what the pressure is, or see if you can hold a gloved finger over the discharge fitting
    Diesel Dave and stylez80Nine Thank this.
  5. bad-luck
    bad-luck Road Train Member
    3,450
    6,362
    Nov 16, 2013
    Baltimore, Maryland
    Compressor may be worn out. Take braided airline off of the back of the Compressor. Put you thumb over the the outlet on the back of the Compressor, it you can hold your thumb on the outlet, your Compressor is worn out
  6. OldeSkool
    OldeSkool Road Train Member
    2,070
    6,651
    Jul 17, 2018
    New Hampshire
    The only two things I’ve had do something similar to that is a bad air leak or the air governor on the compressor going out. Those governors aren’t hard to replace, but they can be a real pain to get the air pressure adjusted right in my experience.
  7. stylez80Nine
    185
    58
    Dec 2, 2018
    Yeah I bout one but don’t look like
    It can be change will try when I get back from vacation. Don’t want to sit for too long.
  8. Deere hunter
    2,171
    10,539
    Aug 5, 2017
    Shallowater Texas
    Stuck one way valve or maybe air dryer leaking. But of course there's 1 million different things that it could be. Pull Your trailer parking brake see if that changes anything tractor parking break,See if that changes anything. And of course, it could be the compressor or the Air governor.
  9. Star Rider
    Star Rider Road Train Member
    1,801
    19,052
    Sep 23, 2019
    I'll go with air leak for $500 Alex.
  10. xsetra
    xsetra Road Train Member
    5,198
    7,150
    Aug 21, 2011
    Compressor Unloader valve.
    Diesel Dave Thanks this.
