Air release 5th wheel
Discussion in 'International Forum' started by earnies2, Feb 23, 2020.
  1. earnies2
    earnies2 Medium Load Member
    691
    281
    May 17, 2012
    Dedham, MA.
    I have 2 blocks on the frame beside the transmission? The front one is much smaller and when I push the button to release my 5th wheel it leaks? I looked at it and thought it was just a fitting but it appears to be the block leaking? Does anyone know the price or part number of this block? Is it repairable? Or just replace it.....
  3. 201
    201 Road Train Member
    12,782
    26,304
    Apr 16, 2014
    high plains colorado
    I don't think I've ever seen an air release 5th wheel that worked properly, just pull the pin!
    ChevyCam, Grumppy and earnies2 Thank this.
  4. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    I have never seen a fifth wheel that releases the trailer the only one I’ve ever seen is the one that releases your pins to slide your 5th wheel,do you have a pic?
  5. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    The air piston them release is your Pins is usually sealed so I just buy a new one.
  6. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    Mine works great at 11 years old like I said the only problem is a slite air leak at the solenoid pack but it still works. I just know that it's going to get to the point that it won't work
    201 and Deere hunter Thank this.
  7. Grumppy
    3,234
    11,402
    Dec 11, 2010
    West Monroe, La
    I've got a 2019 International with one of these 5th wheel air release thingys. I tried using it about a dozen times when I first got it. I bet it only worked maybe 2 out of 10 or 12 tries.
    I just grab my 5th wheel pin puller & manually do it, like I always have.
    201, earnies2 and Deere hunter Thank this.
  8. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    You have been missing out. Look at the pix the top piston is cab controlled and releases the jaws to unlock the trailer
  9. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    On a 2019 it should work perfectly! You can only use it when the truck is running and tractor brakes are set. Do you just flip the switch or do you push it in with your finger? I need to push the switch past on and hold it with my finger until it releases then when I release the tractor brakes the pull handle on the 5th wheel falls and wolla your released
  10. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    thank you for the picture God forbid I ever have one I would unlock the trailer going down the road
  11. Grumppy
    3,234
    11,402
    Dec 11, 2010
    West Monroe, La
    I've held it in until my fingers are sore.
