Looking at an 06, that has an air ride front end.
How are these holding up, it will be put to the test with potholes and frost heaves.
air ride front ends
Discussion in 'Western Star Forum' started by starmac, Oct 10, 2019.
What is it, a Prevost?
IDK, with the trucking you do, it may not be the best idea. Buses don't do well off road,,,I'd have to think an air ride steer semi tractor may not be tough enough. Then there's probably a pesky leveling valve for the front, I say just go with what you know.
I have an air ride front end and have no problems at all. Rides well and a lot less bumpy.
Mike250rs Thanks this. -
If it's a bus type air ride, I might be put off.
If its leaf springs with air bags between axle and frame, I would be more receptive. -
I have hendrickson steertek air ride front axle in my 2012 star. I would get it again in a heart beat. Best riding truck I've had. So far zero maintenance not even a leveling valve .
Our Fitz gliders have them. Only had 1 with any issues, but that driver never met a pothole he couldn't hit.
Honestly it depends on your truck setup if it will help or hurt. Set back axles it will be a smoother ride. Set forward axles it will make your front end " floaty" for lack of better words.
