air scales on trailer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 281ric, Feb 5, 2014.
  1. 281ric
    281ric Road Train Member
    1,248
    809
    Oct 20, 2011
    TX
    any suggestions or input please. Looking to put some on pretty soon.
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I recently went from a standard air gauge to a Right Weigh. Both will work but the Right Weigh is nice.
    281ric Thanks this.
  4. 281ric
    1,248
    809
    Oct 20, 2011
    TX
    are they accurate?
  5. Flightline
    Flightline Road Train Member
    2,345
    1,167
    Oct 1, 2011
    Almost There
    I got the right weigh also. I feel it's accurate with couple hundred pounds. Got the digital guage inside the truck for the drive axles and feel it's more accurate. Probably within a 100 pds
  6. 281ric
    1,248
    809
    Oct 20, 2011
    TX
    Cool Thx. Plan on getting that out the way this week.
    Question for you. what is the smallest big sleeper one can buy? Like yours but not as big?
  7. Bobble
    Bobble Light Load Member
    100
    130
    Nov 26, 2013
    Let me look and see.
    For small sleeper size, look at the next H.O.Wolding truck you see. Most have just a bunk for a sleeper. They give you the option of seatbelting the fridge into the passenger seat or having the seat removed & stored the home base.
    281ric Thanks this.
  8. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    I have a Teltek in the cab and it seems to be accurate within a couple hundred pounds as stated above. Always on the money. I've had it for over ten years and would never trade it for any other. On the trailer I have a right weigh and I guess it's ok. You always have an idea of what's on your trailer but whenever I check the right weigh, it's always saying something way different from what I believe it should be.
    281ric Thanks this.
  9. Flightline
    2,345
    1,167
    Oct 1, 2011
    Almost There
    Ict sleepers start at 96" which is just over factory KW studio 86" sleeper.
    Just remember " Bigger is always better"
    281ric Thanks this.
  10. 281ric
    1,248
    809
    Oct 20, 2011
    TX
    Nah. I meant a sleeper like Flightline has but not as big. A smaller version with all the comforts his has.
  11. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    a cheaper and just as accurate way to weigh your truck and trailer is to simply plumb a schrader valve into each air bag system. read it with a very nice tire pressure gauge. weigh the truck at a cat scale, weigh with your tire gauge.record the pressures. you will be able to come up with "the magic number" . example, 1 lbs. of air on your air bag = xxx lbs. of weight. After a couple of times you will be able to weigh your truck with just this method.. very cheap, very accurate and reliable. hope this helps. johnny
    281ric Thanks this.
