air spring suspension on trailers
Discussion in 'Ask An Owner Operator' started by truckmetal13, Dec 26, 2012.
  1. truckmetal13
    truckmetal13 Light Load Member
    101
    4
    Jan 8, 2009
    Chicago, il
    Any of you have any experience or have any info ,are they are good
    Thanks
  3. interdude
    interdude Light Load Member
    171
    74
    Mar 28, 2012
    smoother and less noise specially pulling m/t or light, spring setup rattles away
    trailer can move up to ~ 6" away from a dock if you don't take care of biz after first docking, gotta wait for the air to dump and back it up again, otherwise there could be probs like a dock plate won't work (can't load then & could be trailer was dropped & left), hook may not release/hang etc.. depends what dock setup is,
    sometimes need a key to override dock sensors, just to unhook,
    basically can end up/have (what did the last driver do) way more dock issues, delays.. someone else may have to be called in (or just around) just to unhook
  4. 25(2)+2
    18,762
    46,074
    Sep 18, 2006
    the road less travelled
    About all I ever pull anymore,last spring ride reefer was an outside trailer that company reused to pull to Colorado during a string of storms the area was experiencing.
    Some dump when you set the spring brakes and others don't, I haven't had much trouble with them walking away from the dock and they load them unhooked for the most part.
    I seldom have a load bounce around with full air ride like it did with just steel springs, and the control is better, IMO.
  5. interdude
    171
    74
    Mar 28, 2012
    only setups i've seen are no dock hook (first) then hydraulic ramp/plate setup doesn't work
  6. VisionLogistics
    VisionLogistics Road Train Member
    1,551
    978
    Dec 8, 2011
    Jellystone
    One of my Utility 3000R reefer trailers has something called Haldex(?) anti-walk, which is supposed to solve the problem, but it still walks 4+ inches, so I dunno.
  7. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    spring ride is like a 5X4 trans. old school. you can tell why spring ride is out and air ride is in just by the way you truck will bounce around. spring is not very good for hauling freight on pallets. the last two pallets will usually b on the floor if you are not careful. you will have less suspension problems with air ride. that being said you will not have air problems with spring. and you should b able to buy a spring ride trl dirt cheap. lots of luck
  8. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    the only time I have noticed having an issue with dock walk is when I am forced to set the trailer brakes.
    Dock walk occurs because the trailer tires CAN'T roll and as the suspension is compressed, the tires are torqued over and then they stay exactly where they are put and the trailer is pushed away from the dock.
    You can tell the brakes are set the way the trailer moves forward.
    This also causes people to have the dock locks hook their DOT bumper and they pull against them and then they bend the hell out of them. It's also a good idea to back up to a dock before you attempt to pull away just in case the dock lock hasn't actually released your trailer.
    VisionLogistics Thanks this.
