AIRBAGS WONT DUMP
Discussion in 'Volvo Forum' started by topwrench, Sep 27, 2020.
  1. topwrench
    topwrench Bobtail Member
    Hi,
    I have 2013 Volvo and I'm trying to fix the airbag problem. The airbags are not dumping from the dump switch, however it shows on the instrument cluster that the airbags are dumping and it also makes a little hissing noise when I turn the switch ON. I manually gave the air supply to the airbag dump line on the suspension valve and it is dumping the bags just fine. I followed the dump airline that goes from levelling valve to the solenoid valves and changed the "ASAP SOL VALVE" but still the problem remains the same. I checked the main air supply on the solenoids it is good because the air horn and the diff. locks are working just fine. Help me if anybody knows about this please.
  3. snowbird_89
    snowbird_89 Road Train Member
    1,029
    826
    Aug 21, 2009
    Massachusetts
    Maybe you need a new dump valve.
