Airline freezing up
Discussion in 'Volvo Forum' started by dphillips, Jan 6, 2015.
  1. dphillips
    dphillips Light Load Member
    82
    8
    May 14, 2013
    I have a 2007 Volvo 670 with a Cummins ISX 400 .how do i keep the air line s from freezing .as I was driving yesterday I noticed my tanks went from 110 which is normal to 150 . I was Bobtailing and the temperature was about -10.there's 2 lines in my air compressor should I put air line antifreeze on the top line out the side line.I changed the air dryer about 5 months ago. And it didn't purge as much as normal I think due to the weather.someone said put the air line antifreeze in the glad hands and run it through the system I have no idea .Thanks
  3. 201
    201 Road Train Member
    12,787
    26,313
    Apr 16, 2014
    high plains colorado
    Hi d, well, the time to deal with moisture in the air system, is before it starts to freeze. Is your air dryer working properly? Line could be frozen before the air dryer. Best thing, would be to get it in a heated garage, and let it warm up and drain the air tanks, if you can do that. I don't think putting alcohol in the glad hands will do it. I've heard of people putting alcohol in the line that goes from the compressor to the air tank, with limited results. Good luck. I'm sure you aren't the only one having problems.
    dphillips Thanks this.
  4. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    An emergency fix is to pop the big line off the compressor (discharge line) and put about a half bottle of air line anti-freeze in it. Then go get a new dryer cartridge, as yours is shot.
    This may cause other issues if that line is the original. It may have a bit of carbon buildup from normal operation, and the alcohol may break that loose plugging things up.
    dphillips and "semi" retired Thank this.
  5. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    Second that pop your service line and dump alcohol in it
  6. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    make sure you use air guard and not rubbing alcohol. the rubbing alcohol contains some water,and will lead to more problems than you already have. be safe out there
    "semi" retired Thanks this.
  7. 201
    12,787
    26,313
    Apr 16, 2014
    Hi j, you are right, I should have clarified that. We always called it "alcohol", but the air guard stuff is the stuff to use.
  8. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    I would not put half a bottle in when it comes to methyl hydrate alittle goes along way mayby 1/2 to 1 cup initially. After that I would go 1/4 cup periotically. After you get it in pump your brakes down let air build and repeat as needed to get alcohol through system. It takes a little time but will work.
  9. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    If you run in cold northern states as an owner operator, try to manage your $$$, and take a break during winter and extreme cold weather; exactly this time of the year;
    Honestly, i learned hard way;used to run Trans-Canada hwy , Toronto- Vancouver and back with apples from Yakima ,WA via I-90/94 ; the money i made didn't cover cold related breakdowns, the truck burns lots more fuel, towing, downtime, roads closed, dangerous icy roads ,chains, accidents;
    I'm parked for 6 weeks; this job is tough and dangerous and 10 times worst for truck and driver health during winter.
    this one cost me about 6000$,
    RubyEagle Thanks this.
  10. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    Don't the service lines have check valves preventing you from being able to help out the truck air system that way?
    Putting it in the big comprest or lines worked for me although I heard recently that it will destroy your air drier cartridge. Take a plug off your primary air tank and dump it directly in there for the absolute best result.
    That being said your cartridge may be screwed already and the compressor lines easiest and works best.
