Alarm Nosies
Discussion in 'Freightliner Forum' started by Big76country, Sep 1, 2015.
  1. Big76country
    Big76country Bobtail Member
    My company just got a new 2016 freight liner and once you dis-engage the airbrakes, the read out on the dash say, PARK BRAKE NOT SET....and the interior dome light stays on....anybody care to take a crack at this?
    Thanks
    Mike
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    make sure both doors are closed. it is sensing an open door.
  4. Big76country
    I have done that!!! and thats what i thought... is the door sensor switch bad?
  5. devedo
    devedo Light Load Member
    114
    43
    Aug 11, 2015
    Does the dome light stay on even with the brakes set???
    You check the resistance in the door jamb switch while pushing it in and out that will tell you.
    Somebody could have slammed the door really hard and damaged the plastic slide to shut the switch properly.
    Had a truck where the only way to get the dome light to turn off was double handed door slammed that rocked the cab....then get out the passenger side so the battery isn't dead next time you try to start it
