Alignments.
Discussion in 'Ask An Owner Operator' started by White_lightning1983, Feb 19, 2020.
  1. White_lightning1983
    White_lightning1983 Light Load Member
    54
    27
    Aug 1, 2019
    Does one have to do an alignment after purchasing and installing a set of drive tires? The last alignment I had done was around October of 2019. Just got a new set of drives... Almost wished I had the truck stop check to see if I needed one.
  3. PE_T
    PE_T Road Train Member
    Not necessary. The alignment measurement goes off the axles and frame. You want an alignment done every 100k or if your truck is pulling to one side on the freeway. A minor pull to the right is normal on the freeway. It’s designed that way so the water won’t sit. The other reason for an alignment is irregular tire wear.
  4. White_lightning1983
    54
    27
    Aug 1, 2019
    Thanks. I'm still new to this game. Going on my 2nd year as o/o
    PE_T Thanks this.
  5. Long FLD
    Long FLD Road Train Member
    12,958
    54,388
    Mar 4, 2015
    If your truck is handling fine and the tires you removed didn’t have irregular wear you don’t need an alignment.
    Also, don’t go to a truckstop for an alignment. Find an MD Alignment shop close to you or get through Kansas City and see Chad at Alignment Solutions.
  6. 201
    201 Road Train Member
    12,820
    26,400
    Apr 16, 2014
    high plains colorado
    Not unless you are building another Hoover Dam or hit a lot of curbs. Some container yards in Chicago might require it. Barring worn parts, alignment shouldn't change.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Another good place is bennnets in gibson pa. Almost a 2-3 week waiting list everytime we've been. Honest guy's, thought the spring bushings needed replacement but they were still good. Could of just as easily said you need new ones. Not too many honest places left anymore
    Snailexpress and Long FLD Thank this.
  8. kemosabi49
    10,992
    47,978
    Jan 13, 2013
    SW Arkansas
    If you ask a truck stop if you need something that they sell, chances are they will say you do. Even if you don't.
    Snailexpress, Long FLD and clausland Thank this.
  9. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    I average 1 alignment a year , truck and trailer.
    Final Drive and Snailexpress Thank this.
