Allison TC10 TS transmission
Discussion in 'Peterbilt Forum' started by PeteSalesGuy, Feb 21, 2013.
  1. PeteSalesGuy
    PeteSalesGuy Light Load Member
    81
    56
    Aug 27, 2012
    Buffalo, NY
    Not really a Peterbilt item, but I had the opportunity to drive a Pete 386 with an MX equipped with the new Allison TC10 TS "automatic" 10 speed. I must say I was impressed with how the transmission operated. This is a twin shaft gearbox that uses a torque converter for starts only. The torque converter multiplies the torque to provide very snappy off-idle starts and then locks up at 4 MPH or less dependant upon load and throttle application, once locked wet clutches shift the five speeds through two ranges to provide 10 speeds.
    Very smooth shifts, it will skip gears if lightly loaded, downshifts quickly and in the higher gears almost imperceptively. The truck was geared with a 2.54 rear and the 10th gear is .86 overdrive so a very tall setup. I was 1160 RPM at 65 MPH and could accelerate from that speed smoothly and with good pull. The Allison people say that proper rear axles spec's will be required to prevent torsional issues with such tall gearing but Dana already had rears designed to reduce the issue as does Meritor.
    Looks like a useable alternative to automated gearboxes. Allsion says the continuous power application as opposed to an AMT will be a benefit and they claim fuel economy will macth other types of transmissions.
    All in all I must say I was impressed althought to be honest they did buy lunch........................
  3. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,845
    Jul 28, 2011
    Glasco,Ks.
    Glad somebody FINALLY got a chance to drive one of these. In my mind it IS the best of both worlds, TQ for starts/stops AND full power shifting.
    That is my biggest complaint with autoshift/ultrashift/ultrshift+/freedomline etc. If you are pulling a long hill and the tranny has to shift a couple of times it loses all/most of your momentum and kills you speed for topping the hill.
    Was this at a dealership for sale, or is this some kind of ride/drive demo?
    Thanks for the info. NEVER mind, just saw you are the PSG and not a driver, I can assume this was a ride and drive?
    Stan
  4. PeteSalesGuy
    81
    56
    Aug 27, 2012
    Buffalo, NY
    Yes,
    An Allison ride and drive.
    There are some TC10 videos on the Allison site and also on Utube. I don't claim to be a
    "driver" so my opinion would need to be taken with caution but I was impressed with operation of the transmission.
  5. 25(2)+2
    18,762
    46,066
    Sep 18, 2006
    the road less travelled
    It should be a good unit and able to do it all from pickup and delivery to OTR. They finally have them out to show off, thanks for your impressions of it.
  6. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,652
    Nov 25, 2008
    Kellogg, IA
    I had an opportunity to drive an end dump in Alaska in the 80's that had an Allison in it. Was very impressed. Never could get on board with on in regular OTR work, but have been following what they have been doing, and would seriously consider using an Allison in a new truck when it comes time. The TC10 looks like they really brought it all together for power, shifting, fuel economy, etc. About time!
