Alternator, Inverter, AC compressor issue?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Kdub99, Sep 30, 2024.
  1. Kdub99
    Kdub99 Bobtail Member
    41
    19
    May 8, 2019
    Hi I was wondering of someone could help me with this,
    I got a 2000 Peterbilt with a Cat
    So i decided to put an Air Fryer in my truck and it runs off the inverter i have hooked in my sleep. The Inverter powers an mini fridge only and the air feyer when i use it for about 2 years it was fine
    Then after anytime i use the air fryer theres a squeel coming from the front if i have the AC on, but if the ac is off no squeel,
    slowly now even with the ac off there is a squeel only when i use the air fryer
    I tried unplugging the mini fridge and using it didnt make a difference
    Is it time to change parts?
    Any ideas?
    Belts and ac compressor are new and adjusted with in the last 6 months
  3. OLDSKOOLERnWV
    18,935
    285,364
    Sounds like you may have alternator belts starting to squeal when under a load….
    Big Road Skateboard Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    Are you hearing a belt squeal or electronic warning squeal? Is the engine running during this? I have heard inverters make a squeal noise when they are starving for power or faulting out. First steps are to always check basic power and ground connections to all those devices and batteries.
    Iamoverit Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,749
    9,119
    Jul 12, 2017
    Belt tension? Sounds like the alternator is slipping under load. Also check pulley wear. If the belt is bottoming out in the v of the pulley it will slip. Once slipped a few times the belt will be no good.
    Heavyd Thanks this.
