Alternator sense wires
Discussion in 'Freightliner Forum' started by Elroythekid, Jun 1, 2022.
  1. Elroythekid
    Elroythekid Road Train Member
    2,620
    5,675
    Sep 9, 2010
    Halifax Nova Scotia
    I have a 2012 Columbia 120 glider kit, s60 12.7 detroit.
    I had a shop change my alternator and now on the hwy my truck is charging at 14.9v.
    I'm not going by the dash gauge, my xantrex inverter had a digital gauge on it.
    The 2 sense wires are hooked up to the 2 bottom terminals with 1 terminal at the top empty.
    Does anybody know if that's right or the color combination and post combination that its suppose to be?
    I've had 2 alternators on the truck since I've had it and both NEVER went over 14.3.
    Thanks!
  3. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    Near dead batteries will do that. Bad alternator regulator will do that. Bad inverter meter will do that. Have you tested the power from "new" alt with a normal volt meter? If no, why no? How long alts serve on your engine before they have to be replaced? What is the reason for them to be replaced? How old the batteries are? Is the alt rebuilt "new", or new "new"?
    Rideandrepair, baha and RubyEagle Thank this.
  4. Elroythekid
    2,620
    5,675
    Sep 9, 2010
    Halifax Nova Scotia
    Batteries 2 months old, fully charged
    Alternator was noisy, bearings were bad, was doing an ac compressor, did the alternator same time.
    Alternator was a little over 5 years old. Replaced it when I bought the truck, same thing, found noisy bearings when changing the belt.
    New delco Remy alternator.
    Just Checked with digital volt meter, it agrees with inverter.
    So, what post combination is suppose to be hooked up?
    Rideandrepair Thanks this.
  5. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    IIRC you have a Cascadia? If so, open the PNDB fuse panel door. Check the fuse labeled "alt sense wire"
  6. Elroythekid
    2,620
    5,675
    Sep 9, 2010
    Halifax Nova Scotia
    No, sorry, 2012 columbia 120 glider. Would have been smart to not assume everyone knows my truck... lol, my halfheimers moment of the day....
  7. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Sense connect terminal should preferably connect to the battery bank but it can be jumped to the large + output lug on alternator
  8. RocketyMan
    RocketyMan Medium Load Member
    549
    337
    Jun 5, 2015
    Gliders can be anything in terms of powertrain options.
    What alternator do you have on your truck? 36SI....28SI??
    There are ways to look up the pin outputs and their function--this is rather easy if you know how to research them. I can help.
  9. Elroythekid
    2,620
    5,675
    Sep 9, 2010
    Halifax Nova Scotia
    This is the alternator I have. Wonder what I should have on the sense wires, voltage wise, when it at a high idol, 1000rpm? 20220605_173007.jpg
  10. Ridgeline
    22,726
    123,425
    You should have the battery voltage on the sense wire. The wire needs to be on the S terminal and hooked up directly to the battery positive terminal.
    The other wire is for the alternator light or a relay.
    The capped terminal on the top is for a tach sense wire.
    if the sense wire is in the alternator light terminal “L”, then you may see high voltage out of the alternator.
    That said the sense wire is usually the larger of the two, which makes it look like it is on the wrong terminal.
    the best way to find out is take the wire off the sense terminal, check for any voltage with the key off, there should be voltage if the wire is the sense wire.
  11. Ridgeline
    22,726
    123,425
