Alternators hot and burning up
Discussion in 'Experienced Truckers' Advice' started by Lowryder1210, Nov 3, 2024.
  1. Lowryder1210
    Lowryder1210 Bobtail Member
    2015 Freightliner Cascadia alternators getting hot and burning up. So far we have burnt up 2 and possibly the 3rd one that is currently on the truck. Checked all wires, changed wires between alternator and starter, cleaned all post on starter and batteries, load tested all batteries. Any ideas? Alternator is getting up to 300 degrees
  3. AModelCat
    165,336
    How many amps are you making it produce?
    How well is the alternator grounded?
  4. Lowryder1210
    All the grounds are good, we have checked to the alternator, to the frame, to the starter to the block all the way to batteries
  5. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    I'd suspect a bad battery or two is failing internally. Years back, had the battery on my pickup go bad internally, it caused the alternator to overheat and fail. The initial assumption was simply a failed alternator, replaced it with a new one, few days later it too was acting up. This was an aftermarket high capacity alternator, took the truck to a local alternator shop and had them test the system, on the vehicle it appeared the alternator was failing, when they took it off and bench tested it, all was fine. They checked all the wiring for shorts/grounds/etc., couldn't find anything. When they pulled and tested the battery, it took a couple tries but they determined that it had an internal fault and was causing the alternator to fail. Worst part was, on the way home, the battery exploded inside the engine compartment, I'd already talked to the battery manufacturer and they were going to warranty replace the battery, after it exploded, well, so much for the warranty replacement as they could no longer test the battery.
  6. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,959
    Oct 31, 2023
    You need actually do a load test on all the ground wires. Too much resistance is the number one cause of excessive heat. A wire can still ohm out even when it's corroded but when the amperage increases it'll fail. Also check to see if you have any draws too.
    dosgatos and AModelCat Thank this.
  7. MAMservices
    MAMservices Medium Load Member
    601
    4,442
    Aug 9, 2021
    I second the bad battery theory presented by Striker. Something has to be telling the electronic internal regulator to charge. This is based on the difference the regulator sees in battery voltage, and the preset voltage to be supplied by the alternator. If there is no great load on the system from an accessory of some sort, it only leaves the batteries to blame. Over 55% of alternators replaced under warranty where i worked, were found to have no faults when returned to the manufacturer over a measured time. We were instructed to do better.
    JolliRoger Thanks this.
  8. AModelCat
    165,336
    I've seen ground cables with nice, clean ends be rotted out inside. Easiest way I've found to test is to run the truck, turn on every possible accessory and measure the voltage drop across the cable.
    One of my pickups had a rotted ground cable. Alternator was throwing out 18-20 volts but the battery was only getting the standard 13.5 volts at the posts. It took 5-6 volts just to push the current through the rotted spot in the cable. New cable, no problem.
    D.Tibbitt, snowwy and Ruthless Thank this.
  9. snowwy
    snowwy Road Train Member
    20,618
    13,339
    Jul 6, 2009
    Unless you're a mechanic with schooling.
    Most have no idea about voltage drops and how to test.
  10. Iamoverit
    2,159
    4,959
    Oct 31, 2023
    That's a great example. Voltage drop testing is a very useful tool. There could just be a few strands carrying low voltage but those same few strands can't handle the full amps because the rest of the bundle is gone.
  11. mustang190
    mustang190 Road Train Member
    2,899
    6,270
    Jan 18, 2011
    Florida Panhandle
    What kind of trailer do you pull and is it hooked up when this happens?
    And check the pigtail.
