Aluminum ground cables?
Discussion in 'Freightliner Forum' started by Intothesunset, Aug 23, 2019.
  1. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Can anyone tell me what genius thought cables for grounds, and positive terminals should be made of aluminum, or was that just a ploy to save a bunch of coin on the new cascadias. And I'd bet all new Freightliner trucks.
    stayinback and 6wheeler Thank this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,555
    6,643
    Aug 26, 2014
    I do not know his name but he was previously employed in the mobile home industry. That is why many of them burned up years ago. It was ran all the way to the recepticals. That is not allowed by code now.
    Something else to look forward to.
  4. fishonron
    fishonron Medium Load Member
    647
    1,661
    Jul 25, 2017
    North Central Kansas
    Aluminum conducts electricity much better than copper and is lighter.
    The majority if not all of the power grid is aluminum cable.
    Aluminum wiring in residential and commercial construction in the 60's and 70's was far more common than copper but there were corrosion issues where the aluminum meets the steel connectors so that's why you don't see it in residential construction today.
    The corrosion led to fire hazards.
    As far as your truck goes I see no problem with aluminum as long as it's not married to a steel part.
    Are you having issues with it?
    If so I'd like to hear what they are.
    misterG, Rideandrepair and BoxCarKidd Thank this.
  5. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    I don't know yet it's a new Cascadia still. But driving a salt belt truck with aluminum cables seems like a real big issue waiting to happen. And no aluminum does not conduct as well as copper. Aluminum conducts current 61 percent as good, compared to copper. Yet is 30 percent the weight of copper. According to Google.
    Rideandrepair Thanks this.
  6. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    are you sure it's aluminum or not plated copper ?
  7. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    Every big cable says on it not serviceable do not repair, replace only.
    Than right near it Aluminum. On a tag. I will get pics later.
    mhyn and Rideandrepair Thank this.
  8. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    must be another new European technology ... :)
  9. Rideandrepair
    17,576
    56,939
    Aug 8, 2015
    I’ve noticed aluminum battery cables on my cars, 08 and 09 GMs. Mobile homes, till 1976. A house down the street, burned last year, aluminum wiring. I’m rewriring my overloaded 14 ga.. copper, with 12 ga. How it ever passed inspection is beyond me. There is a special grease, used for aluminum supply lines, when installing to fuse box. You might want to use some of that, to fight corrosion.
    Intothesunset Thanks this.
  10. Tb0n3
    Tb0n3 Road Train Member
    4,742
    9,662
    Oct 5, 2012
    Earth
    As long as its sized correctly you've got no problem.
  11. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    It's part of corporates return customers policy. See this is top secret information here. Every manufacturer of products made here in this country have a failure test. Example if you buy a cellphone it's designed to update(max out data) so that it fails in 2 years or less.
    Truck manufacturers test everything to find out how long parts last. If the cables last forever then they get rejected and sent back to the test lab to find out how to make them fail in a few years
    mhyn and Intothesunset Thank this.
