Aluminum or steel frame?
Discussion in 'Flatbed Trucking Forum' started by SeanLyman, Oct 28, 2018.
  1. SeanLyman
    SeanLyman Light Load Member
    120
    62
    Dec 9, 2012
    Looking at used flatbeds. I have found a few with aluminum frames going cheaper than steel frames. Aside from weight and corrosion, does aluminum have any disadvantages to steel? Are they more prone to cracking? I can't figure out why some steel flats are going for more than aluminum.
    jamespmack Thanks this.
  3. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,964
    Nov 1, 2017
    The Sticks, Idaho
    When it comes time to have repairs that involve welding the bill will be significantly higher on an aluminum frame trailer. And once aluminum starts to crack it continues much faster than steel. Others May have more hands on experience than I do... I'm just giving info that I know from being a metal fabricator for many years.
  4. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    It will depend on how old your talking and a little about what brand and a lot about what yoour going to haul on it.
    I would say buy the aluminum without any more info. It will always be worth more when you sell it or even scrap it.
    jamespmack and Cattleman84 Thank this.
  5. SeanLyman
    120
    62
    Dec 9, 2012
    Looking at some late 90's Ravens and Benson's. Plan on hauling logs and palletized stone, mulch etc. Definitely be more weight than bulk.
    jamespmack and Tug Toy Thank this.
  6. adayrider
    1,289
    1,732
    May 7, 2018
    That is pretty old for any trailer that has been used its whole life. Good thing is you will be loading the the whole trailer and not concentrated weight of 40-50k in 4-8 feet.
    Aluminum trailers are better made in the mid 2000 though. Bensons suck in the 90's but make a #### good trailer now.
  7. jamespmack
    Don't buy a old ravens unless you like to weld!
    1johnb, cke, Truckermania and 2 others Thank this.
  8. MACK E-6
    50,146
    239,552
    What are you hauling with it?
    I don’t think I would be too comfortable with the idea of loading coils on a used aluminum trailer.
  9. SeanLyman
    120
    62
    Dec 9, 2012
    Logs, pallets of stone etc. Coils are not on my list
    cke and jamespmack Thank this.
  10. Gumper
    Gumper Road Train Member
    1,579
    3,847
    Jan 7, 2018
    Butte, MT
    My aluminum ‘95 Ravens is holding up well for the torture I’ve put it through. I’ve put 46K in 20’, but I won’t haul coils. Have hauled several loads of stone down logging roads with no issue.
  11. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    I have a 99 Benson that I purchased used. It's holding up well and is in better shape than a lot of the newer steel trailers I looked at when I was shopping.
    OLDSKOOLERnWV and cke Thank this.
