Aluminum vs Stainless Weight
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Pamela1990, Dec 23, 2021.
  1. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,721
    Nov 7, 2021
    B.C. Canada
    Even a guess how much more a Stainless steel Super B set of fuel trailers weighs, compared to aluminum?
    Crude Truckin' Thanks this.
  3. RockinChair
    RockinChair Road Train Member
    5,404
    14,551
    Feb 19, 2012
    Lubbock, TX & thereabouts
    I believe a given quantity of stainless is about three times as heavy as the same quantity of aluminum.
    Also, I know that stainless steel is significantly more expensive than aluminum. So unless you're hauling something like DEF that requires a SS trailer and fittings, the aluminum trailer may well be less expensive to purchase in addition to weighing less.
    98989, Crude Truckin' and Pamela1990 Thank this.
  4. Pamela1990
    1,820
    10,721
    Nov 7, 2021
    B.C. Canada
    It will only haul diesel and gas.
  5. BennysPennys
    2,625
    25,275
    Sep 24, 2021
    Aluminum is about one third of the weight of stainless steel. So, are you looking at the Tare Weight of the trailers?
    tscottme, 98989 and Pamela1990 Thank this.
  6. REO6205
    REO6205 Road Train Member
    13,168
    60,501
    Feb 15, 2014
    California.
    If the trailers are going to be hauling only refined petro products I don't see any advantage to stainless steel. Am I missing something here?
    Aluminum trailers, properly loaded and properly maintained, will last a long time. The weight savings over stainless converts to more payload each and every day. That adds up.
    tscottme, mustang190, 98989 and 3 others Thank this.
  7. Pamela1990
    1,820
    10,721
    Nov 7, 2021
    B.C. Canada
    Yes.
    Shopping for used B train trailers, seems hard to find tare weights.
  8. Pamela1990
    1,820
    10,721
    Nov 7, 2021
    B.C. Canada
    It seems that there are more SS ones for sale than aluminum is all.
    I would rather have aluminum.
  9. MacLean
    MacLean Road Train Member
    1,382
    4,097
    Sep 12, 2017
    I’d go stainless. It doesn’t corrode and degrade like aluminum does. I hauled a lot of Sulphur and I can’t imagine using aluminum.
    Rubber duck kw Thanks this.
  10. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,458
    6,865
    Oct 22, 2016
    North Dakota, Eh?
    Hauling fuel and gas? Aluminum. I've never seen anyone haul with stainless. Would be prohibitively expensive upfront and fuel is like anything else, payload is $$$$$$
  11. Pamela1990
    1,820
    10,721
    Nov 7, 2021
    B.C. Canada
    We haven't had any corrosion problems on our other aluminum fuel trailers, so aluminum doesn't worry me.
    Too heavy trailers worries me, as it cuts down on how many liters we can carry.
