ambient temperature sensor
Discussion in 'Ask An Owner Operator' started by -blitz-, Dec 9, 2022.
  1. -blitz-
    -blitz- Bobtail Member
    43
    17
    Apr 26, 2020
    hello everyone.
    i bought a new ambient sensor for my peterbilt 2003 from teltek.
    it was working fine for few weeks and now it has started reading higher temperature. about 45f more than the actual temperature.
    its mounted on the driver side mirror.
    any ideas.
    thank you.
  3. skallagrime
    skallagrime Road Train Member
    3,854
    9,926
    Apr 10, 2012
    Indiana
    Turn off mirror heat?
    Ive got the older teltek indoor outdoor gauge and its accurate but only depending on where i place the probe. Currently i have it zip tied to my fuel pull line, this is obviously suboptimal, but gives me an idea of real ambient temp when i start the truck, but also provides me with an early warning for fuel gel risk. Come spring ill move it again im sure.
    Best location for accuracy would be somewhere it has some air flow, but out of the sun and not directly in the engine airflow that is heated. (Im thinking tucked between battery box and frame) On the mirror is too exposed to sun and if directly on the mirror, will be thrown completely off by the heated mirrors in winter
    Rideandrepair Thanks this.
  4. -blitz-
    43
    17
    Apr 26, 2020
    the issue is i got it brand new and it was working fine where i put it and now after month it just started giving me wrong temp..
  5. skallagrime
    3,854
    9,926
    Apr 10, 2012
    Indiana
    Yes but a month ago was it cold enough to trip an automatic mirror heater?
  6. lester
    2,943
    7,994
    Jan 2, 2012
    NW, Iowa
    Sensor is bad most likely
    Rideandrepair and -blitz- Thank this.
  7. -blitz-
    43
    17
    Apr 26, 2020
    nope it was cold around -22 celsius.
  8. -blitz-
    43
    17
    Apr 26, 2020
    think so too
    yup think so too.. ####ty that its only month old and was expensive..
  9. -blitz-
    43
    17
    Apr 26, 2020
    i will try to change the location and see if it makes a difference. thanks
  10. Derailed
    Derailed Road Train Member
    2,384
    2,657
    Dec 10, 2008
    Upstate NY
    I have mine strapped to my mirror bracket. Its usually spot on within a degree or 2. The heated spot mirror shouldn't affect it. Teltek gauges are great when they work but the harnesses are there weak point. I have to replace mine every few years when they start to read all wacky. Yours may have gotten damaged on installation or just defective.
    -blitz- and Rideandrepair Thank this.
