amplifier to match stryker 955
Discussion in 'CB Radio Forum' started by stacks, Oct 22, 2017.
  1. stacks
    stacks Road Train Member
    1,549
    853
    Oct 27, 2011
    Emerald Isle
    so I'm in the market for an amp nothing big been looking at a zetagi with pre amp also anyone recommend a good amp to go with this particular radio .
  3. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    That is a 90 to 100 watt peak radio as it is. How much more power are you thinking you need?
    Broke Down 69 and Timin770 Thank this.
  4. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    almost gonna need a straight 6 pill to handle the output of that radio.
  5. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Yeap that radio needs a big amp..Nothin less that about 600 watts..More to it than i know about but to do it right its gonna cost you a grand....I sorta threw the idea at mark sherman and that was his reply..At the sam time i was debateing an 2970n4 but was told the recieve of th 955 will have me spoiled compared to the n4
  6. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    Have you heard SOA752 out of Texas on the air? He said he’s running a 955. That is one good sounding SSB rig. He dominated my receive from Grand Bay, AL all the way to Marianna, FL.
  7. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Nope..i rarely get past the carolinas....Most of the time its over modded radios that just 5 ch anove and below the ones they are on..Poorly tuned...They all seem to sound pretty much alike in what they say and repeat,repeat,repeat themselves..
  8. Dirtymartini15x
    Dirtymartini15x Light Load Member
    180
    114
    Oct 18, 2016
    A straight four transistor amp is plenty big enough for that radio. It's only a 70-80 watt radio, not 100 plus like a lot of people like to think they are.
  9. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Lol sooo true...@ 60-70 range they get their best performance with clean audio
    @ 100 wattts its a over heated scatter box..
    But with the proper tune and a good antenna set up it will perform like 100 plus watts..
    Dirtymartini15x Thanks this.
  10. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    Since the newer Chinese transistors have drastically less gain, you'll need more transistors to make up the difference.
    Eight 2sc2879 transistors would be a minimum I'd recommend.
  11. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Mark has his source but question is,for how long!!
