My cb, a bearcat 880, stock mic, antennas and coax, has a terrible swr...over 2.5 most of the time...and will only reach out about a mile or so.
The last three weeks I've been running through horrendous weather...ice and snow left and right...and I started to notice something interesting .
When my antennas iced up my swr started dropping and my transmit/receive range would begin to open up...a lot. As soon as the antennas thawed, back to poor ranges. I have actually seen a 1.00 swr and 12 mile range in all this winter weather.
Any explanation for this or extrapolations for when I upgrade my cb and antennas...looking at a general Lee or Stryker 955 if that's at all relavent, not sure on antenna setup yet.
Just curious if there's some lesson to be learned here.
An interesting phenomenon
Discussion in 'CB Radio Forum' started by Broke Down 69, Jan 21, 2017.
Ice is changing something in your system. Is it completing a ground? if you grab the base of the antenna when drydoes it improve the swr?
rabbiporkchop and Broke Down 69 Thank this. -
Yes it did. Bad ground? 2015 Coronado with stock factory mounts.
check your antennas. sounds like something may be loose and/or you have cracked antennas. (I'm assuming they are stock fiberglass)
check all the bolts and connections are tight, even under the plastic cover. ice/moisture may build up and complete a normally broken circuit which would explain why you have a lower swr when you are in icing conditions.
a cracked antenna may cause high swr when it swings back and forth but when it ices up and holds still it may have a good connection. (this has actually happened to me before)rabbiporkchop and Broke Down 69 Thank this. -
Thats strange my SWR goes skyhigh when the antenna accumulates ice. A week ago I was parked in York NE during ice storm Jupiter and my Swr was 3.0+, once everthing thawed out things got back to normal.
bored silly Thanks this. -
If grabbing the base of your dry antenna improves your SWR it usually indicates a poor ground. You body is completing the circuit.Broke Down 69 Thanks this.
Any suggestions for improvement? I'm not much of an electronics guy but I am pretty handy and can follow instructions pretty well.
As LB suggested make sure everything is clean and tight.
Broke Down 69 Thanks this. -
I did all that and checked for cracks in the antennas, no change. How and where to add grounding strap(s)?
It all sounds like sorcery to me.. just saying.
