Ancra ratcheting winch
Discussion in 'Flatbed Trucking Forum' started by pavrom, Jul 15, 2020.
  1. pavrom
    pavrom Road Train Member
    3,217
    7,416
    Apr 29, 2012
    NE illinois
    Did anyone tried those ?!
    I just put 2 on my step to try out .
    650cat425 and singlescrewshaker Thank this.
  3. Long FLD
    Long FLD Road Train Member
    12,902
    54,118
    Mar 4, 2015
    My old boss ran them on his Conestogas because of the way the track was set up. I don’t think he ever had any issues with them.
  4. singlescrewshaker
    4,867
    42,592
    Dec 31, 2017
    Little Havana, FL
    I have not tried them, but I can see how they will come in handy, especially on a lo-pro step, which I believe both you & I run..
    If you experience the same issue as I, with the winch bar hitting the ground before the dog catches the next tooth, but can't get the bar in the next winch hole.
    Just keep them lubed up.. :thumbup:
  5. pavrom
    3,217
    7,416
    Apr 29, 2012
    NE illinois
    Thats exactly what i have .
    I use car hauling tightening bar that is 3/4 thick all the way and comes in different lengths , i still have longer than i should be using but it helps a lot .
    Will make pic for you later
  6. pavrom
    3,217
    7,416
    Apr 29, 2012
    NE illinois
    Here you go !
  7. singlescrewshaker
    4,867
    42,592
    Dec 31, 2017
    Little Havana, FL
    LoL, man I'm thick headed! I should get one of those too.
    My solution thus far has been over inflating the trailer air bags to get the extra clearance needed between the bar & the ground..
    Thanks man! :thumbright:
    D.Tibbitt Thanks this.
  8. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    I just used a shorter bar. :dontknow:
    singlescrewshaker and TripleSix Thank this.
  9. TripleSix
    133,434
    I use a steel punch that's about a foot and a half long. Some rgns will have strap ratchets on the side, and if you're trying to secure a wide crate with straps on an rgn, you will find yourself lying on the ground, underneath the load, and that solid short bar is the only way to tighten the straps.
  10. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    Mine was similar; a solid hexagon bar about an inch and-a-half across and about the same length.
    Doubled for freeing frozen brake drums without having to get under the trailer by putting it through a wheel hole and tapping with a hammer. :D
  11. TripleSix
    133,434
    Winner.
    not4hire Thanks this.
  12. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    I run regular flatbed. When I'm hauling steel, and go really tight, I love that full length bar. A shorty, I know I would lose a tooth or 2.
    singlescrewshaker and D.Tibbitt Thank this.
