2001 w900 c15 6nz cat. Noticed this morning coolant is leaking past cap on surge tank. Any ideas what would cause this? Cap is about 2 months old. And is 10 lbs.
another coolant leak
Discussion in 'Kenworth Forum' started by cumminsISB, Jul 23, 2014.
Get a rad. press. tester and bring eng. up to op. temp with tester on in place of cap to see if it is building up lots of press. in rad. a oil sample test will tell you if anything is in oil yet?
i think it supposed to be 16 lbs.double check.good luck.
16 lbs is the one for your engine the 10lb one will release to soon and leak
^ This. 10 PSI is way too low.
