Another fault code
Discussion in 'Ask An Owner Operator' started by pumpkinishere, May 22, 2022.
  1. pumpkinishere
    pumpkinishere Heavy Load Member
    945
    4,988
    Apr 21, 2021
    Spn 157. We are hoping not to mess with until we get back home. Messina, NY and Burlington Vermont Monday morning. Then hope to be able to drive to Indiana before doing something about this. Do you all think that’s possible. Or will this fault code shut us down?
  3. pumpkinishere
    945
    4,988
    Apr 21, 2021
    Oh we are in New York Messina now. I forgot to mention that.
  4. pumpkinishere
    945
    4,988
    Apr 21, 2021
    This fault code came on after 40 hrs of idling.
  5. Siinman
    Siinman Road Train Member
    5,536
    14,243
    Mar 5, 2017
    Kansas City, MO.
    I believe this is a fuel related issue. How is your fuel filter looking? Any leaking anywhere?
  6. pumpkinishere
    945
    4,988
    Apr 21, 2021
    We recently changed our fuel filter we don’t see any leaks anywhere
  7. Ridgeline
    22,768
    124,364
    You may need to change them again, I had this issue a couple times and it turned out to be debris in the fuel system. It was starving for fuel on the fuel rail.
  8. Siinman
    5,536
    14,243
    Mar 5, 2017
    Kansas City, MO.
    If not put on correctly it can cause same issue as well. Just a FYI
  9. Upstatetrucker
    Upstatetrucker Bobtail Member
    29
    96
    Nov 15, 2020
    There is a KW Dealer in South Burlington/Shelburne VT if it gets to that point were you need to have it checked out.
    pumpkinishere Thanks this.
  10. flood
    flood Road Train Member
    4,169
    4,051
    Dec 25, 2010
    I had the same code... ended up being fuel filters
  11. pumpkinishere
    945
    4,988
    Apr 21, 2021
    That’s good to know just in case.
