Another glitch or bug. NYC fix
Discussion in 'HAMMER: Truck Optimized GPS App | Support Forum' started by HardwareHyena, Nov 5, 2020.
  1. HardwareHyena
    HardwareHyena Light Load Member
    138
    138
    Nov 17, 2011
    Depew, NY
    Heading west on the Long Island Expressway towards Queens, it says to take the Syosset exit44 (route 130) only to go around the loop back on 495 goin same way.
    NavigatorWife Thanks this.
  3. Adele Allison
    Adele Allison Bobtail Member HAMMER Support
    23
    18
    Oct 7, 2020
    Hi @HardwareHyena, That does not sound right I am going to forward this to our developer to look into. You may also want to check your truck presets and confirm if you have any options to avoid when routing because can alter your route.
  4. b61mack
    b61mack Light Load Member
    60
    70
    May 18, 2010
    port murray nj
    Possibly GPS is picking up low bridge on the LIE, NY mark them a foot lower. 13'6 would be marked 12'6" up the bridge height on your GPS. Also the low measurement is for the shoulder height
  5. Adele Allison
    23
    18
    Oct 7, 2020
    Hi @b61mack Thank you for letting us know, I am going to forward this to our developers to look into.
  6. mpow66m
    mpow66m Heavy Load Member
    819
    529
    Jul 6, 2011
    Northeast
    Theres a low overpass on the LIE i belive.its .Its really 13'6'.ignore it.Of course be sure first.Theres plenty of low ones on the exits,but as far as i know there are no low ones on 495.
    NavigatorWife and HardwareHyena Thank this.
  7. Adele Allison
    23
    18
    Oct 7, 2020
    Hi @mpow66m thank you for bringing this to our attention, I have escalated it to our developers to look in to as soon as possible.
    mpow66m Thanks this.
  8. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Why does NYC put incorrect measurements on bridges? Once you find out, how can you believe any of their signs?
  9. mpow66m
    819
    529
    Jul 6, 2011
    Northeast
    Everything is a foot higer than listed.Unless it says avual height is xxx.Sign colors mean nothing.Yellow is the standard warning,while white is the posted height usually on the structure.Both are a foot higher than posted.Why? Who knows i heard so many different stories.
  10. diamondd817
    diamondd817 Light Load Member
    159
    560
    Oct 11, 2020
    NYC driver of 22yrs here. I go under 12'1 marked overpasses with 13'6" trailer all the time. NYC tip: if it's a yellow height sign it's at least 2' more than marked. If it's a white height sign it's 1' more than marked. Best tip: if it looks like it's been hit, it's less than 13'6", if it looks like it's never been hit, it's more than 13'6".
    You can travel the entire length of the LIE (495) both directions in any lane with 13'6" and you will not hit anything. Also, you can travel the entire length of the BQE (278) both directions in any lane with a 13'6" and not hit anything.
  11. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    the road less travelled
    Axle center to the top is height marked. As close as I could get is around 12 foot actual and 12 1 in practice. Running around under those big roads can be unnerving, although they finished up construction onthe BQE on the western end. The big bridges have an upper deck and a lower deck, trucks on upper deck only except if detoured off. I've been on both decks of the Verrazano both ways and I didn't go that much.
    High winds can be a problem, too. The longest view out is off Throgs Neck headed back to The Bronx to the right(seaward).
    They took out the tollbooths, too, the Port Authority EZ Pass is the best to use, but the vehicle can be registered and billed electronically, unregistered were ticketed, and that's why we finally got EZ Pass.
    That works on some of the big bridges on the west side of Jersey, too. And it's much nicer to not have to stop to pay them.
