OK, I posted on here before and got quite a few good pieces of advice. I have a 6-meter (don't ask me why) and a 2-meter on the truck with just standard whip antennas trimmed to the center of the bands, but I want to upgrade. I want to get rid of it all and put in a Yaesu FT-857 with an ATAS 120. For those of you who don't know what these are, see the links below. Anyone on here use a similar set-up? How well does the ATAS 120 work for you? How do you have it mounted? Do they make a mirror mount for it? I am assuming all it needs is an SO-239 right? Thanks
Yaesu FT-857 link: http://www.amazon.com/gp/product/B0...N=B004TB9JUI&linkCode=as2&tag=lifofamodtru-20
Yaesu ATAS-120 link: http://www.amazon.com/gp/product/B0...N=B004UM9UL4&linkCode=as2&tag=lifofamodtru-20
Another Ham Radio Question
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by CobraDane, Oct 23, 2013.
To quote K0BG, the mobile antenna guru:
"In fact, the Yaesu ATAS antenna is the least efficient, remotely controllable, HF mobile antenna, money can buy!"
http://k0bg.com/antennas.html
That said, I do have the original ATAS-100 on my ancient FT-100. My old 20m Lakeview Hamstick worked noticeably better. (Before it whacked that tree branch, that is.)
I have it on an MFJ-342S on my Volvo. The whip sticks up a bit above the tractor, and I've "twanged" the whip a few times (passenger door) on tree limbs. You MUST ground the mount! I also recommend taking the extra coax and making a ~4" coil at the mount to choke off the RF flowing on the shield.
Would I go with the ATAS again if I had to buy a new antenna? No. I've seen a few mirror mounted Little Tarheel antennas on the road, and I would likely go that way, even if it means paying extra for a separate auto controller unit. -
I have heard a bit about the tarheel... I might look into it a bit more
CobraDane: It is not a comparison, go TARHEEL reason #1. You get a better resale value If you decide to sale it and upgrade, in a few years to a real automatic screwdriver antenna such as the HiQ series Piranhas (built trucker tough 2nd behind the Scorpion), the Scorpion (I think the Top Dog of all auto-screwdriver antennas), then there are the larger Tarheels and the GS auto screwdriver antenna by gs-mfg.com (which has a very good user reputation). The following antennas fall ito a pecking order that necessitates having to get a automatic screwdriver antenna but you do not have enough green backs $$$$ to purchase a REAL auto-screw antenna as shown above.
4. www.alpineantennas.com
5. www.diamondantenna.com yes diamond now makes a auto screwdriver antenna!
6. www.highsierraantenna.com
bottom tier is a tie between
7. a. Yaesu's ATAS antenna
7. b. MFJ attempt at a auto screwdriver antenna
Aim High! .......... ............. ........................ ................................ just my opinion, others may differLast edited: Nov 8, 2013
There is a different Diamond antenna website for ham radio stuff. The link goes straight to the screwdriver product.
