Another swr question
Discussion in 'CB Radio Forum' started by KAK, Nov 25, 2012.
  1. KAK
    KAK Medium Load Member
    518
    2,073
    Feb 10, 2012
    Ne
    I know the swr meter in the radio's are not very accurate. When I check with an external meter I am getting 2.s and 2.5's on the external and the same on the radio meter. I unhook the external and only get 1:3 to 1:4 on the radio meter. Is my external meter giving me a high swr or should I trust it ??
    THANKS
  3. Mt Airy
    Mt Airy Light Load Member
    57
    11
    Aug 25, 2012
    I have almost the same radio is you and I checked mine with a external meter both were the same . Did you calibrate the external meter ?
    KAK Thanks this.
  4. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    X2...also the internal meter has an adjustment on it that will read incorrectly if incorrectly adjusted.
    KAK Thanks this.
  5. MsJamie
    MsJamie Road Train Member
    Out of curiosity, how long is the cable between your radio and SWR meter?
    KAK Thanks this.
  6. KAK
    518
    2,073
    Feb 10, 2012
    Ne
    External calibrated, not sure how to calibrate the internal. 3 ft on my jumper cable. Just not sure why it is changing on the internal meter with the external meter hooked up vs not hooked up.
    You have to remember I know just enough to be dangerous and mess things up :biggrin_25523:
  7. MsJamie
    The coax in your setup is acting as an impedance matching network. Adding the extra coax is upsetting that match. I bet that if you coiled up a few feet of that coax and measured again, the SWR would change.
    The proper place to check SWR is right at the antenna. Any other place has the coax influencing the reading.
  8. KAK
    518
    2,073
    Feb 10, 2012
    Ne
    So how do I go about checking at the antenna ? Run a long jumper from the radio out to the meter and a short one to the antenna ??
  9. Powder Joints
    7,988
    8,407
    Sep 25, 2007
    Rosamond, SoCal
    Actually I find the internal SWR bridge to be just fine, only if some screwdriver jockey has been in there to mess it up. I find about a 3 foot jumper works fine.
  10. MsJamie
    Pretty much. If your antenna has a PL-259 connection at the antenna, you can use the existing coax. I use a short (6") jumper between the meter and antenna.
    To be honest, since the internal and external meters agree, I would just trust the internal meter on the regular coax. <1.5:1 is fine.
    It just occurred to me that your jumper coax may be bad, as well.
  11. twolane
    twolane Medium Load Member
    468
    252
    Dec 16, 2010
    Arizona
    I'd never contradict MsJamie but here is my experience...
    I've noticed that alot of drivers believe that they can adjust the swr with with the calibration knob on their radio or meter. This is not true!
    For those of ya that may not know...here's the drill for checking swr no matter internal or external meter.
    I go to ch. 20 initally.
    Find the switch that lets you choose "calibrate", key the mic. and hold it keyed, while you adjust the "calibrate" KNOB until the meter reads AT the calibrate pointer at the top rhs of the meter. Release the key & choose SWR at the switch. Don't touch that knob! Key the mic and see the meter. The LESS it moves the better. The calibrate knob does not change anything. It only "calibrates" the meter.
    Maybe MsJamie can explain this better but that calibrate KNOB doesn't change anything!
