Antenna grounding
Discussion in 'CB Radio Forum' started by TheGodfather, Jan 11, 2018.
  1. TheGodfather
    TheGodfather Bobtail Member
    4
    Sep 4, 2012
    Phoenix,AZ
    Ok so I know this issue is covered in multiple threads. My question is when running my grounding straps can I hook one up to a magnet attached to the frame to keep it as short as possible rather than having to find a bolt somewhere to use? Thanks
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Magnet Mounted antenna's don't need a ground strap...
  4. TheGodfather
    4
    Sep 4, 2012
    Phoenix,AZ
    Sorry guess I didn't clarify, it's not a magnetic mount. It's mounted on my mirror bracket. Was wondering if I could use a magnet to ground to frame. The kind with a bolt and wingnut like ovwraiae guys use
    jessejamesdallas Thanks this.
  5. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    NO. And don't run a ground strap from your mirror all the way to your frame either. If you need to ground, bond actually, you want to use short straps 18" or less. Mirror arm to door; door to body; body to frame. Braided straps are best, coax works pretty good. Just solder the center conductor to the braid where you terminate it. Make sure you get good connectivity, sand to bare metal at each point of contact, then paint it to protect from rust after you're done.
  6. Phenix
    Phenix Bobtail Member
    Jun 22, 2016
    Thanks Mike. I do know not to run one long ground strap. I've already got one from the bracket to the door and sooebto body just need that last short connection from body to frame.
    mike5511 Thanks this.
  7. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Actually there is metal flake or somethin like that in almost all paints so you dont "have to" sand down to metal..Still can if ya wanna but,just sayin
  8. Ridgeline
    22,730
    123,542
    Metal flake was in the paint vehicle - the liquid that is used to spray the paint on the object and has some condictivity. Once it is dry, there is no conductivity.
    If you want to have a good ground, then you sand all the coating off the metal for it to work.
  9. Phenix
    Jun 22, 2016
    So if I understand correctly, sand down a small section on the frame to bare meatal then just solder the wire right to the bare spot?
    Can I then paint over it for protection?
  10. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Yes you can paint over it once installed...Mater-a-fact you need to to keep it from rusting... As for soldering, I just use a self tapping screw to attach the ground braid...Put some solder on the end of the ground braid, then run a self tapping screw through the solder to the body or frame...The solder will keep the braid from coming unraveled when you run the screw into it...or you can crimp a eye-connector to each end of the braid for the screw.
  11. Ridgeline
    22,730
    123,542
    The solder may act like an insulator if you coat the braid with it completely. You need to just use enough to put on the very end to 'seal' it.
    Yes Paint it, if you can paint it with some epoxy paint so it doesn't flake off. Prep it first to make use there is no oil or solder residue on the connection or area.
