antenna help!!
Discussion in 'CB Radio Forum' started by jcashtrucking, Sep 16, 2011.
  1. jcashtrucking
    jcashtrucking Light Load Member
    51
    9
    Jul 29, 2011
    the cb shop is telling me that i need a long shaft antenna to get my swr lower, what antenna is the best for the money, just confussed as to the diff in 19.99 and 109.99
    was recomended to use the wilson with the 10" shaft
  3. Diesel Dave
    9,774
    33,740
    Jan 20, 2010
    Hesperia, Ca.
    The BEST antenna for your buck is FRANCIS.
  4. musicmaker
    musicmaker Medium Load Member
    561
    145
    Dec 25, 2009
    Fort Madison, IA
    When The signal is reflected from the top of the truck, on some trucks, the shorter shaft antennas will not pick up some of the signal, thus making a higher SWR
  5. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Standing Wave Ratio - Power transmitted out/power reflected back =%swr.
  6. am89
    am89 Light Load Member
    101
    12
    Aug 1, 2010
    METRO NYC
    The 10" shaft is used so that the radiating part of the antenna, is above the reflective metal part of your vehicle.
  7. mike5511
    mike5511 Road Train Member
    3,157
    1,547
    May 15, 2011
    NW Arkansas
    If a Francis in 4 1/2 or 5 1/2 foot length wouldn't work, I would go with the Wilson. If I owned my own truck, I would probably go with a "Monkey Made".
    I'm experimenting on a Frieghtliner Cascadia now. Haven't found an ideal solution yet. I am using the mount you can see at the link below. A Francis 5 1/2 foot works pretty good (18ft coax) if you lean it forward. The further you lean it forward the better the SWR, but of course after about 18-20 degrees of lean you start losing efficiency. Evidently as you lean the antenna forward it gets further away from the truck body and mirror, which causes less reflection thus a lower SWR, (like am89 said) I have a Wilson 2000 with a 10" shaft I'm going to try next and see how that works. I tried a Monkey Made with about a 14" shaft and that didn't work out so I don't know if the Wilson will be any better or not. Probably end up going with the 5 1/2 ft Francis leaned forward. Of course if you drive the same truck all the time you could invest in some additional grounding and probably improve things immensely.
    http://www.walcottcb.com/cas1-freightliner-cascadia-antenna-mount-p-2062.html
  8. jcashtrucking
    51
    9
    Jul 29, 2011
    i have just gotten the wilson with the 10" shaft. swrs went down to 1.3 so im all good thanks for the info!!
  9. Rat
    Rat Road Train Member
    The reason is that the plastic ball in the middle of the antenna actually has wire windings in it to make the antenna longer without adding actual height. The longer shaft will get the the ball and majority of the antenna up and above the roof line which makes it work better.
    They are what some call a center loaded antenna. Fiberglass antennas usually have most of their windings in the top portion of the antenna which makes them able to perform with a shortler actual length. What some call a top loaded antenna.
    But I see you got the 10 inch shaft and all is good so no worries.
